Brake Vibration
Old May 29, 2014 | 08:31 PM
phenoyz's Avatar
Brake Vibration
when I go downhill speed is 85-95mph the moment I step on the brakes the car vibrates....but on normal city stop and go traffic when I brake there is no
vibration on the car.
DO i need a new brake rotor and brake pads?
I went to a mechanic and he is charging me $347 for a NEW brembo rotor
and akebono pads, it includes labor everything. Is that a good deal?
(those are basic rotor and pads i guess)
Can anyone suggest a good brake rotor and brake pads?
thanks
Old May 29, 2014 | 09:07 PM
tmfit's Avatar
Most likely warped rotors. Sorry have no idea if that is good price but I would look at getting the rotor turned if there is enough stock on it since the heat cycles on the rotor are stable.
Old May 29, 2014 | 09:32 PM
myfoxmystere's Avatar
brembo rotors
Brembo is a commonly used aftermarket rotor. I've had no problems with Brembo rotors. My late dad's 1980 Honda Civic Wagon brakes work well with them. If your rotors are worn past their minimum thickness, this will be a decent replacement rotor.
Old Jun 3, 2014 | 10:33 PM
demouser's Avatar
I just did our 06 Civic. Hawk street pads were about $75 and parts store rotors were about $75. I guess $347 for brand-name pads and rotors is OK considering overhead and labor.
Vibration at high speed could be sticking caliper pistons or slides which can overheat the rotors at high speeds.
Old Jun 3, 2014 | 11:52 PM
ikutoisahobo's Avatar
Get the rotors machined if you don't wanna replace them.
Julien Griffault
May 14, 2021 08:04 PM
wskwong
Jan 26, 2010 12:13 PM
mikejet
Sep 12, 2009 11:12 PM
FELIXY69
19
Jul 19, 2009 09:22 AM
Nino NoSpam
Aug 11, 2005 09:30 PM
