Stuck in need of help
Old Jun 23, 2014 | 10:10 PM
HONDA4LIFE420's Avatar
So I'm not the best with wheel fitments and stuff wanting my first set of wheels for my fit I'm lowered on tein springs I'm looking at rota Jmags but I always see them on first gen fits when I try to search online for a ge8 I wanna do 16x7 40 offset will there be any issues with that on my 2013 any info would be great
Old Jun 23, 2014 | 11:15 PM
ROTTBOY's Avatar
Originally Posted by HONDA4LIFE420
........16x7 40 offset will there be any issues with that on my 2013...........
The specs will fit a 2013. It all depends on your tire size of choice. If your going 185/55x16, it won't have rub issues.
Old Jun 24, 2014 | 01:03 AM
Thanks for the info I've been told a lot of sizes I'm bad with sizing rims and tires still kinda understanding how it all works I just do t wanna rub but don't wanna have crazy stretched tires either not a fan of that look just want some nice wheels at a good prices now to decide if I want black or polished on my white fit
Old Jun 24, 2014 | 04:15 PM
Wiings's Avatar
You'll be fine. I'm on Eibach Sportlines (2" drop in rear 1.8" drop in front) running 16x7 +35 which is 5mm more poke than yours, and I don't rub AT ALL
Old Jun 25, 2014 | 11:05 AM
Thanks man just wanna be sure before I go spend the money I am finding it hard to part with the 13 rims life decisions
Old Jun 25, 2014 | 12:09 PM
should fit, but depending on the tire you get you might rub a little bit. my winter set is a 16x7 ET40 with 205/50/16 Continental DWS. it rubbed just a little early on in the front, but no more rubbing even at full bump. i even run a 5mm spacer on the rears.
Old Jun 26, 2014 | 12:53 PM
I gonna prob go with 195/50/16 seems to be a safe size since you kinda rubbed on 205 is your car lowered
Old Jun 26, 2014 | 01:32 PM
Wanderer.'s Avatar
You will be fine with 195/50/16 with those specs. You may rub a little with 205/50/16 but nothing serious.
Old Jun 26, 2014 | 05:45 PM
Now I gotta just get thru these stock tires 35000 miles and there still all good a little uneven wear cause I lowered it with no alignment but nothing to bad
Old Jun 26, 2014 | 06:29 PM
Wanderer.'s Avatar
I never aligned my car after I lowered it. It's been about 60k miles and nothing unusual. All of my tires have lasted the advertised mileage or longer.
It's pretty hard to screw up the alignment much with McPherson strut front end as long as you don't slam the car.
HONDA4LIFE420
May 5, 2014 03:42 PM
EvoFit
Feb 6, 2011 06:48 PM
Kurse
Apr 15, 2009 02:03 PM
GBjaynu
Aug 6, 2008 12:32 AM
Alan_Fits
May 22, 2006 07:53 PM
