Oil Light (Blue)
Old Aug 13, 2014 | 01:33 AM
yuffers's Avatar
Oil Light (Blue)
Weird thing happened today where I started my car and the oil light was on (but blue).
It was on for probably 1 minute once from when I started it to when driving for a little.
The car was parked for the work day 9am to 6pm.
I looked at the manual and I believe it was a notification for the oil temp being too cool? Anyone ever experience or know of anyone?
Steel Grey - EX
Old Aug 13, 2014 | 02:01 AM
john21031's Avatar
It was probably the coolant indicator that glows blue until the engine warms up a bit (approximately 1-4 minutes depending and temperature and the engine load). Oil light should be red. Do not worry. Pay close attention though.
Old Aug 13, 2014 | 02:20 AM
yuffers's Avatar
This was the light that was on for a bit...and thank you for your response!
Old Aug 13, 2014 | 05:13 AM
tmfit's Avatar
Yes it is the coolant light indicating it is not to temp yet.
Old Aug 13, 2014 | 05:16 AM
yuffers's Avatar
Weird I live in LA and it's pretty warm (but car was parked in a parking garage)
Do I have to wait until it's off to drive? Is this notification new. Never really seen this on my older cars.
Old Aug 13, 2014 | 05:25 AM
tmfit's Avatar
First I have ever seen it on a car. I never wait, it goes off within a minute. May be different come this winter in Ohio.
Old Aug 13, 2014 | 08:41 AM
15BlkPrl's Avatar
Honda has been using the blue coolant temp indicator for a few years now. First one I remember was on the then new 2007 Fit. It saves gauge cluster space by not having a germinate coolane gauge on the dash and is less prone to failure.
The gauge indicates the engine is not at optimal operating temperature yet.
You can drive the car with it lit just take it easy until the light goes off.
Old Aug 13, 2014 | 08:59 AM
BrianKearsey's Avatar
The light goes off when the coolant gets to 53 deg C or 127 deg F, that's when Honda deems it warm enough.
Old Aug 13, 2014 | 09:30 AM
m_x's Avatar
m_x
Mine has been on every morning when I start it, and I live in south Florida. I've only had the car since Sunday though. The first day I waited maybe 30 seconds and it turned off. The other two day I didn't think about it and it went off before I was out of the driveway.
If it is calibrated to go off at 127F, I'm assuming it will be on for a few seconds anytime the car has sat for a long period of time.
Old Aug 13, 2014 | 09:42 AM
spreadhead's Avatar
You can look this (and many more things about your car) up in the book that came with your Fit!
Old Aug 13, 2014 | 10:07 AM
8strung's Avatar
Mine does this pretty much every time I start the car after it's cooled off
Old Aug 13, 2014 | 11:59 AM
oman's Avatar
Same here, even after sitting in the 95 degree Texas sun. Takes 45 seconds to a minute to turn off.
Old Aug 13, 2014 | 08:40 PM
Mason Jerman's Avatar
Smile
I get this often when i start up on my 09 fit sport. I dont think its an issue. I would check in your manual.. But i believe its just you telling you the engine is cold. Also it may be that your oil is going to be do for a change soon. I know mine is about due.
hope i helped a bit
Old Aug 13, 2014 | 08:47 PM
15BlkPrl's Avatar
hope i helped a bit
Again the light is only a cold engine temp (cars coolant not up to operating temp) . It will turn on every time you start the car after allowed to cool off for a wile. Light will come on until the engine comes up to operating temp. Generally anything from +-30 seconds to 2 minutes.
Old Aug 13, 2014 | 11:12 PM
Odie's Avatar
Toyotas have same light . Just start and go . Takes a Toyota auto tranny longer to go to overdrive ( 4th ) . Know this from several Yaris we had .
Old Aug 14, 2014 | 01:37 AM
MTLian's Avatar
Same experience with my car. I wouldn't worry. Just drive normally. I would avoid flooring it and revving it past 5.5k rpm until the light is off and the oil is at an optimal temperature.
Old Aug 14, 2014 | 04:59 PM
Howdy's Avatar
That blurry picture makes it look like a sailboat on the water.
Old Aug 14, 2014 | 08:33 PM
Raziaar's Avatar
Same here. Even on relatively hot days in Texas.
lschiffer
Jun 3, 2023 01:07 PM
SilverEX15
Sep 21, 2014 03:28 PM
DarkStorm
Aug 3, 2009 04:35 PM
Etrsi_645
Nov 2, 2007 12:01 PM
acidic@tokyo.com
May 4, 2005 11:16 AM
