Rear Disc - Seriously Trying to Get OEM DIY Sorted Out
Old Aug 19, 2014 | 01:27 PM
apexanimal's Avatar
-Test fit pics in post #59
-How-to in post #83
-Install pics in post #84
CONVERSION BRACKETS
-scarebird brackets - i'll post a link once they list them for sale officially
DISC
-any rear disc from a 1997 Acura Integra (NOT the type R)
-the ones I used: Centric rear disc - 12140017
PAD
-any rear pad from a 1997 Acura Integra (NOT the type R)
-the ones I used: Stoptech Street Perf rear pad - 30903740
CALIPER
-rear calipers from a 1997 Acura Integra (NOT the type R)
-the ones I used (came with clips, bleeders, banjo, and crush washers): Centric reman rear caliper - 14140532 L; 14140531 R
-you'll also need the parking brake arms and bolts: 43267-sh3-931 L arm; 43247-sh3-931 R arm; 45240-sc2-003 bolts (4 bolts needed)
PARKING BRAKE CABLES
-87 acura legend coupe: BC94043 rear left; BC94044 rear right
-holding and cotter pin: 43471-SD2-930 holding pin, 90705-SD2-931 cotter pin
BRAKE LINES
-contact Fastbrakes.com and ask for the Honda Fit conversion brake lines - swivel end, good quality/price
OR, make your own
-approximately 36" in length, female 10x1mm end, 30-45* banjo 10x1mm end
you can do it cheaper than I did, but I spent $540 total... the largest expense being the calipers, conversion brackets, then brake lines, and on down...
Old Aug 19, 2014 | 01:57 PM
TPColgett's Avatar
Still may never do this (lite weigh is key for me and good front pads/rotors/fluid is all I need for AutoX) but tagging for info and interest!
Old Aug 19, 2014 | 02:01 PM
kylerwho's Avatar
spoon fed
I was always under the impression del sol rear hub was used with del sol rotors and ep3 calipers. Still didn't learn what ebrake cable to use though.
Old Aug 20, 2014 | 03:35 PM
apexanimal's Avatar
does anyone have a picture of a gd rear spindle?
am i correct in saying that they are bolted onto the rear axle?
found this on ebay and it's intriguing...
Old Aug 20, 2014 | 03:46 PM
apexanimal's Avatar
here is a pic of the old t1r spindle:
fastbrakes.com modified bracket (on a ge):
jdm rear spindle:
http://img247.imagevenue.com/img.php..._122_120lo.JPG
ebay one i just found (note that it rotates the caliper up slightly, which isn't a deal breaker... but... don't know:
Old Aug 20, 2014 | 04:01 PM
TPColgett's Avatar
From my rear camber shim project:
Hope that helps
Old Aug 20, 2014 | 04:05 PM
apexanimal's Avatar
thanks tp
can you remind me what the top and lower center bolt holes are for?
Old Aug 20, 2014 | 04:56 PM
apexanimal's Avatar
discovered that the 1997 integra rear brakes = the del sol rear brakes...
i sent a message to the ebay gentleman to ask him about rear spindle/caliper brackets and if the ones that are sold for the del sol will work for us... and if not if they might develop them (they'd be pretty darn similar)...
we'll see how this goes...
Old Aug 20, 2014 | 07:11 PM
apexanimal's Avatar
keeping it going...
does anyone have a p/n or, even better, know the length of each of the parking brake cables in the gd honda fit? rock auto is letting me down...
or getting to the point, does anyone who bought a kit know the length of the parking brake cables that they were given?
Old Aug 20, 2014 | 07:14 PM
swade's Avatar
Would be down for a nice diy/oem rear disc
Old Aug 20, 2014 | 09:04 PM
kylerwho's Avatar
spoon fed
looking at the ebay brackets you would need to drill a few holes for the abs sensor and the countersunk hole for the allen bolt.
Old Aug 20, 2014 | 09:49 PM
apexanimal's Avatar
^i noted that as well... what is the allen bolt for if the other four hold it onto the axle?
(its been a while since i've been back there...)
Old Aug 21, 2014 | 12:54 AM
jmsplitfyre's Avatar
Hmm. Interesting. Tagging for interest.
Old Aug 21, 2014 | 09:30 AM
apexanimal's Avatar
here's our question wish-list at this point:
1. does anyone who bought a rear disc conversion kit from t1r or fastbrakes, know the length of the parking brake cables that they were given per side?
2. on the rear spindle, what is the bottom center allen bolt for if the other four hold the spindle onto the axle?
3. what is the thread size/pitch of the honda fit brake lines at the rear drum? (do the conversion kits simply hook into the very end of the rear brake line or further forward?)
and as a note. it seems the clock that the fastbrakes kit and the ebay brackets put on the caliper is ideal to aid in properly bleeding the rear calipers... the t1r brackets don't place the bleeder valve quite high enough in relation to the piston...
Old Aug 21, 2014 | 02:46 PM
apexanimal's Avatar
In my best Top Gear voice: "GOOD NEWS!!"
Scott,
We think we will have you handled in 2-3 weeks. We have ordered the parts we need. We will then develop and test. As with our other brackets, we will design for off the shelf parts. We anticipate the brackets will be about $ 100.00.
*takesabow*
so roughly, price-wise, here's what we're looking at:
-brackets - $100
-rotors - $20
-pads - $30
-reman calipers - $200 (no core refund included)
-parking brake cables - $60
-ss brake lines - $60
APPROX TOTAL = $470
Old Aug 21, 2014 | 08:28 PM
kylerwho's Avatar
spoon fed
I would definitely be down for a custom rear bracket.
Old Aug 21, 2014 | 08:51 PM
TPColgett's Avatar
Sounds awesome!!!
Old Aug 23, 2014 | 04:18 PM
apexanimal's Avatar
BMW Alpina reports on the GE that the parking brake cables that are needed are,
Total length of the parking brake cables from end to end about 69 to 70 inches.
still need some help finding out this info:
2. what is the length of the rear ss brake lines that you ended up using?
Old Aug 26, 2014 | 01:21 PM
apexanimal's Avatar
just got another email from mark at scarebird... as we thought the current brackets they make don't work for the fit, but he said they are working on creating new ones and will let me know when they're ready for test fitting!
more good news
Old Aug 26, 2014 | 08:53 PM
apexanimal's Avatar
so it looks like they've got their design done, and will be sending it into their laser cutter with the next batch of stuff... so in 2-3 weeks they should have it in hand...
they're basing it off the 96-01 acura integra rear brakes (NOT the "R" version)... I think this will be good to help keep rotating and unsprung mass, and brake bias good for those of us who want to stay stock front sized stuff...
i'm working with them to get fitment and the parts list together for everyone... so once i have it and have confirmed that it works, they'll put it up for sale for everyone.
I DO NEED HELP with these things:
1. what is the length of rear brake line for the 1997 acura integra (the length that is replaced when doing ss lines)?
2. ANYONE who has purchased and installed a t1r kit or fastbrakes kit: what is the length of the cables? and any pictures of the setup would get major +rep and a big up from me...
3. feedback on reman caliper brands? which are decent/which are crap: centric, raybestos, a-1 cardone, nastra, beck/arnley, retech, wagner, power stop, napa eclipse, altrom?
