Broken Input Shaft Bearing? :(
Hello, I started a thread earlier about a broken motor mount. I've since ordered a replacement mount and changed it but the knocking sound remains.
the sound occurs in neutral when my foot is off the clutch. When I depress the clutch, the sound goes away. Here's a YouTube link: sorry for the bad camera work, I was focusing on the sound more than the video.
If it's coming on and off with the clutch engaged vs disengaged, I'd think it might be something to do with the clutch assembly or the transmission. Whichever one it is, I assume you'd have to remove the transmission and/or the clutch to troubleshoot it. So if I were you I would just order parts and pick a day or two to begin taking things down.
Could be the pilot bearing, throwout bearing, maybe pressure plate? Might just need to take it apart and have a look, because you'd have to take it apart to replace any damaged parts anyway.
$300 is a great price, and he would be removing the clutch anyways to change pilot bearing.
Exedy makes a great clutch kit, they usually rival or exceed OEM specs.
Grab a set of axle seals and a change's worth of tranny fluid, grab 3 quarts of honda MTF just in case. Pulling axles out drains fluid
That sure sounds like a release (throw out) bearing riding on the clutch diaphragm (pressure plate) spring. It is hard to tell not being there. I have never pulled a Honda Fit clutch but on those I have worked on there were a couple of clips to hold the bearing away from the clutch when it is disengaged. Also there is an adjustment procedure in the 2009-2010 Fit Maintenance manual page 12-5. All I have here is paper copy so I can not post it. The fix may be as simple as adjusting the clutch pedal according to the manual to allow clearance between the release bearing and the clutch diaphragm (pressure plate) spring.
Thanks for the heads up. I'll take to my mechanic for a listen and if it's just an adjustment I'll do it myself.
In the Honda manual it was section 12 the clutch was listed just prior to the section with the manual transmission. I have never seen a Helms manual for the fit so I do not know how it is organized. I was hoping someone here had the manual electronically and could send you page 12-5.
I did notice a racing/revving sound with the pedal completely pushed in when downshifting (when pushing the shifter in second gear with the clutch to the floor). Could it be the clutch is not fully disengaging and rubbing on the pressure plate?
I am GUESSING that the clutch linkage may be holding the release bearing up against the pressure plate. It probably is not holding it tight enough to make the clutch slip, but it is touching just enough so the bearing is not disengaging completely and dragging on the pressure plate. If this is true you might get by just adjusting it back slightly. You also may end up having to replace the release (throw out) bearing because it has been spinning for who knows how long and may be badly worn. If you can adjust it back just slightly and the noise goes away, you may get by not having to do anything more.
TroyGgd3
Oct 26, 2016 08:30 AM
s0x
Nov 14, 2014 06:47 PM
Nvillegas
Jan 17, 2014 06:22 PM
