Progress RSB new hardware
Old Aug 26, 2014 | 12:59 PM
gd3david's Avatar
I just received my Progress RSB last week and am going to install it this weekend. I've noticed from reading old installs that the original hardware provided by Progress were Hex head bolts, although the hardware provided with mine is a button head style bolt. Just clarifying that the button head style bolts are better to use for this install, correct?
I know this has been covered a lot over the years in other threads but I just wanted some clarification and noticed that Progress must have changed the hardware that they provide with the RSB.
Old Aug 26, 2014 | 02:17 PM
kylerwho's Avatar
spoon fed
Yes everyone was switching to panducky I believe was the company providing button style Allen bolts. The hex heads that progressive supplied just tore the bottom of the rubber spring perch. The bolts you got will work just fine as long as the bolt is facing down with a nut on the bottom.
Old Aug 26, 2014 | 07:17 PM
gd3david's Avatar
Perfect, thanks! Any concerns with how the spring sits after install due to the tops of the bolts?
Old Aug 26, 2014 | 09:48 PM
Hootie's Avatar
No issues should be had with this style bolts if installed the with the button head bolt facing down (towards the ground) with either OEM or aftermarket lowering springs.
Old Sep 2, 2014 | 06:12 PM
gd3david's Avatar
Awesome, sounds good. Thanks Hootie!
Old Sep 2, 2014 | 09:55 PM
Rollerboots666's Avatar
Use JB Weld. Super grip and works great!
Joking yeah thats the right hardware.
Old Sep 2, 2014 | 11:29 PM
geopat's Avatar
And some black zip ties.
drumsauce
Nov 19, 2010 01:25 AM
elmaynardo
31
Mar 17, 2010 07:29 PM
CuTeBoi
20
Dec 31, 2008 09:25 PM
trancedsailor
Nov 22, 2008 01:36 PM
