What is the REDLINE RPM for a GE Fit?
Old Sep 11, 2014 | 01:59 PM
Oneoldphlaytis's Avatar
And how do you know?
thanks
Old Sep 11, 2014 | 02:03 PM
i forget. it's near noon position though, and the redline itself i hard to see. end up hitting rev limiter often.
Old Sep 11, 2014 | 02:18 PM
Wanderer.'s Avatar
6800 RPM is when the limiter kicks in. The tach actually reads about 7k when you get there but I think but there's some error.
Old Sep 11, 2014 | 02:36 PM
i guess the question to the op is WHY?
Old Sep 11, 2014 | 05:32 PM
WHY? Though its too late to make any difference for my Fit, if you look at the "break in driving" threads, some talk about at what mileage you should let the car get to what % of red line. It occured to me that for the Fit, I have no idea what RPM is red lined and when I looked in the owners manual, I didn't find it. 6800 rpm, I will have to take a closer look at my tach, I never noticed a red line on it before.
Old Sep 12, 2014 | 11:34 AM
yah, just drive it gently the first 1k miles. that's all. as long as you dont mash the gas abruptly, even if you hit redline occassionally you're fine.
same goes for the brakes.. easy braking.
Old Sep 12, 2014 | 11:20 PM
13fit's Avatar
proper breakline entails various levels of aggression occasionally, and never maintaining a constant speed the first 500 miles or so.
These newer engines tend to break in a bit faster since they are built to much better tolerances then of old.
DO NOT change the oil early. make sure you get at least 3-4k miles. THe oil put into the new engine has specific additives and detergents to allow proper break-in, and is doing its job of clearing metal debris much better then any off the shelf oil.
utsug
Sep 8, 2015 06:26 PM
haudoodles
Dec 12, 2014 10:23 AM
colnago
Jun 30, 2014 04:45 PM
Fluxmerc
Sep 22, 2012 02:40 AM
x_25
Feb 13, 2012 01:58 PM
