coolant leaking from this plug
Old Sep 21, 2014 | 04:19 PM
mxl180's Avatar
I'm hoping it's just the rubber hose. I believe the larger blank hose it connects to is metal (hoping it's not leaking from there). Any it's dripping.
Coming from EGR. I'm assuming I would have to bleed the system after installing a new hose. Any idea to stop the flow during install?
Old Sep 21, 2014 | 10:33 PM
MTLian's Avatar
You could use vice grips set at a very soft pressure so you don't damage the hose.
Old Sep 21, 2014 | 10:38 PM
mxl180's Avatar
It's was a pain in the butt to reach it. The leak was on the rubber host right after clamp. I ended up taking a box cutter on it. Cut off where the leak was and reattached. I did lose a lot of coolant. Planning to refill it tomorrow hopefully the coolant bleeds easily.
Wreck Ignition
Mar 14, 2024 03:24 PM
doctor J
Jan 23, 2019 03:02 PM
Kasek
Jul 10, 2018 06:15 PM
theo.chan@gmail.com
Oct 19, 2005 02:39 PM
mmdir2002@yahoo.co.uk
May 4, 2005 04:44 PM
