T1R, Weapon R header cel eliminator
Old Sep 26, 2014 | 05:56 PM
magnumkdb44's Avatar
To those who have a header installed on their ge8 I'm wondering what kind of check engine light fix you have and if it works in keeping the light off. Thanks.
Old Nov 25, 2014 | 12:04 PM
Orcshine101's Avatar
Im pretty sure its the o2 sensor in the header. After swapping out my t1r header my cel went off too. Too much oxygen flow i guess
Old Dec 3, 2014 | 02:23 AM
07fit916's Avatar
so is it just on? or did you find a way to turn it off?
Old Dec 12, 2014 | 08:39 AM
Myxalplyx's Avatar
I just ordered this yesterday.
Weapon R CEL Eliminator
I'm surprised I can not find a thread specific to this device, except for this one. Hoping it works.
Old Dec 12, 2014 | 09:37 AM
07fit916's Avatar
Just installed t1r header in my GE. Put a generic defouler on the 2nd o2 sensor. CEL is gone.
Old Dec 12, 2014 | 10:21 AM
Myxalplyx's Avatar
What defouler did you use (Name Brand)? What CEL did it get rid of?
Old Dec 13, 2014 | 02:35 AM
07fit916's Avatar
it was just a no name brand from my local tuner shop.
ended up using only the L half of it.
code was P0420 - Catalyst System Efficiency Below Threshold Bank 1
Old Dec 18, 2014 | 10:46 PM
bensenvill's Avatar
interesting, I've always seen CEL eliminators made with a little bit of circuitry (I've made a few its just some resistors and capacitor in parallel IIRC). I guess whatever works.
Old Dec 18, 2014 | 10:59 PM
Myxalplyx's Avatar
I have a Weapon R CEL Eliminator just sitting in my mailbox now. I thought I'd need it after getting rid of both cats but no code came up for that. Only code I have is for EGR low flow. Saving it, just in case it wants to pop up after a while of driving.
Old Dec 20, 2014 | 05:03 PM
Steven Hung's Avatar
I brought the same O2 defouler from eBay to fix the CEL after installing T1R response header. The L-half also triggered the same issue with Catalyst System Efficiency Below Threshold bank 1 on my car. L-half together with the O2 sensor extension or the straight piece also triggered the same problem. The O2 sensor extension by itself did the trick. It has been over eight months and there is no more CEL. However the O2 sensor wire is a bit short. I did have to extend them to avoid getting it too close to header or the exhaust pipes. The O2 sensor wire seems to be stainless steel. I had to use silver soldier that melts at higher temperature to soldier the stainless steel wires to a heavier gauge copper wires.
jjboyes06
Jan 19, 2011 10:19 AM
t3chn0rav3rb0y
30
Jan 19, 2010 09:24 PM
im the fit
19
Feb 9, 2009 03:22 PM
Kuturagi
Apr 16, 2008 04:49 PM
dman77fb
21
Oct 31, 2007 12:07 PM
