Playing Music from a Flash Drive
Old Sep 29, 2014 | 12:06 PM
SilverEX15's Avatar
A couple of weeks ago, I inserted a small flash drive into the front USB slot, and I could play music from it. I recently updated the music on it, but I can't see a way to access it now. What am I missing? "Source" shows me AM, FM, Bluetooth, and iPod.
Old Sep 29, 2014 | 12:14 PM
Jack92029's Avatar
The owners manual has several pages of excellent info on this subject, no need to repeat it here
Old Sep 29, 2014 | 01:05 PM
SilverEX15's Avatar
If only that worked!
Basically, insert the flash drive and select it with the Source button. And when that doesn't work - as it did two weeks ago?
Old Sep 29, 2014 | 07:14 PM
tmfit's Avatar
That should be all you have to do. Do you have the USB port in the armrest also? If so try it there and see if it picks it up
Old Sep 29, 2014 | 07:24 PM
cheesewhiz's Avatar
Or try your query on one of these previously well-established, highly informative threads:
https://www.fitfreak.net/forums/3rd-...ash-drive.html
https://www.fitfreak.net/forums/3rd-...ory-stick.html
https://www.fitfreak.net/forums/faq....faq_vb3_search
Old Sep 29, 2014 | 09:11 PM
tmfit's Avatar
Has it worked since you had that panel out? Wonder if the came has worked loose?
Old Sep 29, 2014 | 10:16 PM
cheesewhiz's Avatar
That's right! Forgot SilverEX did some R&R in that area. On my LX 5" display the USB symbol shows up on the top of the display even if audio system is turned off ... it shows that a USB device is connected and similarly shows blutooth connectivity. With the ignition set to accessory you should be able to see connectivity on your display: IF no USB symbol THEN no music.
As tmfit suggested try the other USB in armrest: if audio system recognizes something is connected then you have issue with other port; if it doesn't recognize a device connected on either port you have bigger issues.
On the other hand if you DO show connectivity on both ports (but won't play files) then you just have an issue with the thumb drive ... maybe f-ed something up when updating the drive. Try wiping out the drive: delete everything.... maybe even re-format, start from scratch. Then move the files back to the thumb and try again.
Good Luck! Post update of your findings
Old Sep 30, 2014 | 07:26 AM
SilverEX15's Avatar
It was my stupid mistake. I have a FitBit that uses a tiny USB plug-in, and it looks almost exactly like my tiny flash drive. That's what I inserted into the slot in my Fit. Of course it didn't work. Now I'm back to normal.
Old Sep 30, 2014 | 02:50 PM
cheesewhiz's Avatar
..... OR it could be PILOT ERROR!!!! You "Buddy-Bugged" yourself! Do you work on the shift before me by any chance? I get a lot of this at work
Old Sep 30, 2014 | 03:03 PM
SilverEX15's Avatar
I got one of these little guys. It's so small that the USB door can close over it.
Amazon.com: SanDisk Cruzer Fit 16GB USB 2.0 Low-Profile Flash Drive- SDCZ33-016G-B35: Electronics Amazon.com: SanDisk Cruzer Fit 16GB USB 2.0 Low-Profile Flash Drive- SDCZ33-016G-B35: Electronics
Old Sep 30, 2014 | 03:43 PM
cheesewhiz's Avatar
Mini
I LIKE IT!!! Need one real bad ... thnx!
BTW .. what is a FitBit?
Old Sep 30, 2014 | 04:25 PM
tmfit's Avatar
Glad you figured it out! We are often our own worst enemies :-P
Old Oct 20, 2014 | 11:07 PM
ADVphotography's Avatar
Fitbit is Awesome. I use the FitBit One and its just a little thing that you clip on your belt that's pretty simple in its own right. It counts steps. BUT since its teamed up with their software you get a lot of data. Calories burned, step goals, floors climbed, and sleep tracking. Being able to see my sleep data before and AFTER my baby was born is worth laughing about. End Rant.
Old Oct 21, 2014 | 03:40 PM
SilverEX15's Avatar
I keep mine in the watch pocket of my jeans, but that would be a perfect place for my Fit "key." Maybe I'll bring all my pants to a tailor and make sure they all have two watch pockets. I never thought of clipping it to my belt. I'd be afraid that it would get knocked off. The FitBit site says to clip it to your bra. I'd be too embarrassed shopping for a bra, and I think it would look funny under my shirts.
I used to enter all the food I ate on the FitBit site, but that got to be a nuisance. Mine doesn't track my sleep, but that's okay, because I'm usually asleep then, anyway.
wwjd
Dec 2, 2020 08:37 AM
nuoccam
Sep 9, 2011 06:23 PM
dontaskbrad
Jun 25, 2010 11:29 AM
weatherman
Apr 1, 2009 09:02 PM
ynotb17@yahoo.com
Mar 2, 2009 09:54 PM
