Maintenance Minder
Old Oct 22, 2014 | 01:05 PM
Mike4100's Avatar
Maintenance Minder
Hello,
I have a second hand 2008 Fit, only 40k mileage.
The maintenance minder %15 oil life B12 with wrench has come on.
I was quoted around $300 from local Honda dealers, and I would like to get the oil and filter change done elsewhere for around $30 and change the filters myself if possible.
I am not experienced with car mechanics and this is my first car.
I am pretty sure I can rotate the tires myself, and I need to put winter tires on anyways so that will cover that aspect.
How difficult would it be to perform (2)
-Replace air cleaner element
-Replace dust and pollen filter
I had a safety inspection about a month ago so most parts should be working fine as far as the maintenance inspection goes.
Thanks
Mike
Old Oct 22, 2014 | 01:29 PM
domoMKIV's Avatar
I doubt it is going to be much different (I have an 07) but changing the filter behind the glovebox is maybe a 15 minute job at most and same with the engine filter.
Should cost around $25 for both filters, depending where you buy them.
Edit:
Cabin filter -
Engine filter -
Old Oct 22, 2014 | 01:49 PM
Mike4100's Avatar
Thanks,
Is there a certain brand of filters that I should buy or do you have any recommendations?
Old Oct 22, 2014 | 02:00 PM
domoMKIV's Avatar
Old Oct 22, 2014 | 03:42 PM
Mike4100's Avatar
Originally Posted by domoMKIV
I usually use tyc for the cabin, there are other brands though. If a fram is cheaper, I wouldn't hesitate to buy it.
Amazon.com: TYC 800125P Honda FIT Replacement Cabin Air Filter: Automotive
Engine - fram, oem or wix...whichever is cheaper at the time.
Amazon.com: Fram CA10650 Extra Guard Panel Air Filter: Automotive
Great thanks!
Old Oct 22, 2014 | 07:53 PM
If you have an '08 Fit, its probably a GD, not a GE.
Old Oct 22, 2014 | 08:09 PM
Mike4100's Avatar
GD/GE?
Has anyone used a K&N lifetime filter?
Old Oct 22, 2014 | 08:22 PM
GD = First generation
GE = Second generation.
You posted this in the GE section, however if you're in North America and drive a 2008...its a GD.
Old Oct 22, 2014 | 08:59 PM
domoMKIV's Avatar
Don't know how I missed that.
Old Oct 26, 2014 | 10:00 PM
chickentickler's Avatar
cabin filter
I bought mine at the dealership but didn't let them install it. They charge double!
Old Oct 26, 2014 | 10:16 PM
Mike4100's Avatar
I bought a fram ca10233 for my 2008 fit, from Canadian Tire for $12!
I ordered the cabin air filters online for $10.49.
It takes less than a minute to install, and you save quite a bit!
Old Oct 26, 2014 | 10:26 PM
MTLian's Avatar
I actually use a fram cabin air filter because it's cheaper than the OEM.
Old Oct 27, 2014 | 01:56 AM
john21031's Avatar
Originally Posted by Mike4100
GD/GE?
Some people use them, but I wouldn't.
They are not filtering as well as the oem filter and I wouldn't want to damage the engine with dust particles of larger size getting into the engine from the use of a reusable k&n filter.
The oem filter is 10$ where I buy them and they last 25-30K miles.
Why would I want to use K&N?
Old Oct 27, 2014 | 02:01 PM
MTLian's Avatar
I feel like a K&N drop in is kinda like a lateral move. It's still about the same kind of air flow. I'd rather just keep changing a paper filter regularly than spend 40$ (or whatever it costs) for the k&n.
However, I am currently considering the K&n cold air intake, which some would argue makes only a small difference if any, but at least it would allow better airflow since you are removing some of the baffles of the stock air box.
puffysweater
Mar 18, 2017 10:52 AM
mandobaron
May 30, 2015 02:58 PM
thefit09
Jul 12, 2013 04:21 PM
clemsonteg
Mar 1, 2013 04:16 PM
Juliane
Sep 29, 2009 07:08 PM
