If I am going to mod front end....
Old Nov 14, 2014 | 12:41 PM
TaubBaer's Avatar
I read that USDM headlights are crappy (?) and I normally drive at night.
I am wondering if I can use JDM projectors with USDM grill and bumper? I checked the Japan and US websites, the grills are different but the shape of grill and bumper looked the same to me.
Old Nov 14, 2014 | 12:44 PM
kenji815's Avatar
USDM head lights work just fine.
nothing crappy about them.
JDM projector wouldn't work correctly cuz they are RHD it would be even crappier.
Old Nov 14, 2014 | 12:57 PM
Fitmo's Avatar
My only complaint with the USDM lighting is that I cannot use the fogs with parking lights only to get rid of the glare of the low beams. I can with our Ford truck.
It would also be nice to use the fogs to fill in up close when the high beams are on. I did that with the driving lights on my Road King and it made a huge difference at night.
Since all that appears to be in the turn signal switch, I will probably wind up just running a separately switched circuit to the fogs so I can have them on when I want them on.
Old Nov 14, 2014 | 03:08 PM
DArkk's Avatar
Hmm... The fog lights are on a separate switch which I can turn on and off along with automatic mode. Yours doesn't have one?
Old Nov 14, 2014 | 03:19 PM
Fit Charlie's Avatar
Fog lights only working while the low beams are on isn't a Honda thing, it's a state law thing. Maybe not in your state, but in enough places that cars are generally just made that way. If you have auto headlamps then they're technically "on" so you can turn the fogs on or off as you please.
Old Nov 14, 2014 | 04:14 PM
Fitmo's Avatar
It does... but unlike my stock Ford truck, it ignores me when the main light switch is in parking light position.
In Auto, it only turns the fogs on when it turns the low beams on. If the turn signal switch is in the high beam position (pushed back toward the dash), Auto will never turn the fogs on.
Old Nov 14, 2014 | 06:27 PM
TaubBaer's Avatar
In our Hyundai Sonata Limited, the fogs only work with low beams, when switch to high beams, the fogs are off.
Old Nov 14, 2014 | 08:09 PM
Fitmo's Avatar
TaubBaer, do your fogs work with parking lights only?
Old Nov 15, 2014 | 10:56 AM
Fit_as_a_butchers_dog's Avatar
I have fog lights?
That is so cool.
Old Nov 15, 2014 | 11:03 AM
Fitmo's Avatar
Not really. The purpose of fog lights is to provide a low cut-off alternative to headlights, which glare in the fog.
Since you can't use them without low-beams, the Fit has fauxg lights.
Old Nov 15, 2014 | 05:07 PM
TaubBaer's Avatar
Tested last night, When I turn off the headlights to parking lights, the fogs turned off, too but DRL switched on.
Old Nov 17, 2014 | 07:11 AM
Fitmo's Avatar
Thank you.
Old Nov 17, 2014 | 12:47 PM
Actually, their purpose is to warn other people that the driver's brain is in a fog. That's why so many people have them on all the time.
s0x
Nov 21, 2014 10:12 PM
mike410b
Mar 21, 2014 02:10 PM
JasonBrown
Jun 19, 2011 01:42 PM
kimonostereo
Jan 23, 2009 05:05 AM
pwnstar
May 22, 2008 12:01 PM
