DIY: OEM Big Brake Kit
Old Dec 9, 2014 | 12:19 AM
gd3~fit's Avatar
Did a quick search on this and if it's already been posted, my apologies, I didn't find anything nor saw a sticky for it.
I had this DIY BBK done on my previous 2 Hondas, Integra and a Civic and it's a cheap reliable upgrade.
Has anyone done this to their Fit yet? I will be trying this come Spring, I don't see why it wouldn't work, the front brake system is the same size as the Integra. Anyone know if it will clear the Sport rims?
Parts Needed:
Calipers from Integra Type R Front, remanufactured. Any 97-01 Acura Integra Type R.
Rotors from Mini Cooper 4x100, 280mm diameter front
+ your choice of pads
Some how to threads already:
DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR - Team Integra Forums - Team Integra
DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's! - Honda-Tech
ProParts USA prepackaged deals:
DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR - Page 29 - Team Integra Forums - Team Integra
I wish the Fit had OEM rear disc setup and not drums. If it did the rear upgrade would use RSX Type S rear calipers with EP3 Si Civic rear discs.
Old Dec 9, 2014 | 12:25 AM
Hootie's Avatar
If I remember right the ITR/CR-V front calipers would barely nip the factory GD Sport alloys. Give me a second and I may be able to find the DIY.
Edit: Here it is.
https://www.fitfreak.net/forums/fit-...tallation.html
Old Dec 9, 2014 | 12:46 AM
gd3~fit's Avatar
Edit: Here it is.
Thank you for that link. Looks like I will have to use a spacer for the front if I want to keep the stock Sport rims.
Benefit of this DIY, uses cheaper OEM Mini Cooper rotors full BBK for under $200
De36
Dec 1, 2025 05:40 PM
phenoyz
Jul 22, 2018 11:42 PM
GTornado
36
Jul 26, 2010 04:27 AM
Tofuik
May 17, 2009 03:13 AM
orhanz33
Jan 26, 2009 07:50 AM
