Question for you motorheads
Old Dec 12, 2014 | 06:53 PM
hogwylde's Avatar
What benefit/difference is there between a DOHC vs a SOHC? (besides the obvious 1 cam vs 2! )
Old Dec 12, 2014 | 09:32 PM
DrewE's Avatar
DOHC allows you to do without rocker arms, which has some at least theoretical advantages (fewer moving parts, less mass to accelerate/decelerate so possibly quicker valve actuation). From a maintenance point of view, it's typically easier to adjust valves on an SOHC because you can have adjustment screws on the rocker arms, while a DOHC uses something along the lines of shims that have to be swapped out.
In practice, it doesn't make a vast difference IMHO. I recommend using however many camshafts came with the engine from the manufacturer.
sunnyday
May 27, 2017 09:18 AM
doctor J
Dec 20, 2015 12:55 AM
R3born
Jun 21, 2015 05:27 PM
tonyd3773
Feb 10, 2008 12:22 PM
Steve
Sep 12, 2005 09:30 AM
