3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
GK Camber Bolts
Old Dec 28, 2014 | 09:08 PM
jhn's Avatar
jhn
GK Camber Bolts
SPC #81260 work great
Old Jun 5, 2017 | 02:28 PM
s2kookies's Avatar
Thanks for the info. I was trying to find out what Camber Bolts people were using and this is the only thing I was able to find. I just put in my order for mine and will drop back in when they arrive to confirm my fitment aswell. Thanks JHN.
Bump for others looking.
Old Aug 10, 2017 | 03:56 AM
ClifFit's Avatar
If I am just getting a H&R + Koni Orange setup to lower the car, are camber bolts necessary for the alignment afterwards? Or can the car be lowered without the camber bolts?
thanks!
Old Aug 11, 2017 | 08:16 PM
hasdrubal's Avatar
Considering most of the people here who post about lowering don't seem to use them, you will probably be fine. There are two general reasons I see to use camber bolts. First, if you track your car and need negative camber to give extra grip in turns, or second, if you have either wider tires or a different offset and want to pull the upper edge in to keep them from rubbing on the fenders.
Old Aug 12, 2017 | 04:04 PM
thanks!
you can run without camber bolts. actually there's really no adjustment on the Fits besides front toe.
but from a performance perspective, when i lowered my GD and especially the GE, i ran -2 degrees on the front which added a lot more bite during turns vs stock. the open diff really kills the exit of the turn so you want max tread contact while turning.
Old Jan 4, 2018 | 10:47 AM
matthorkan@gmail.com's Avatar
Does lowering the fit add positive camber that needs to be corrected with the camber bolt? I have a highway car (stock 2015 LX) so i'm ok with very slight (close to 0) camber but i dont want it to be 0 or positive after lowering. The front and rear suspension geometry is radically different, how do they differ when lowering? Thanks.
Old Jan 4, 2018 | 03:31 PM
fit419's Avatar
I went with 0 toe and -1.5 degrees up front when I lowered my car on Swifts. I love the extra bite and turn in response.
Old Jan 5, 2018 | 01:01 AM
hasdrubal's Avatar
The rear is a trailing arm setup, and camber is not affected by lowering. The front is a MacPherson strut, and if anything might see a slight negative camber when lowered, but very slight. When I lowered my car, I also added wider tires (205/50/16) on aftermarket wheels, and without the camber bolts it causes rubbing on the fender liners. If you go with narrower tires or a different offset, you may not need them.
Old Jan 9, 2018 | 09:24 AM
fit419's Avatar
I thought I'd add that I just switched to my winter wheels yesterday and did not see any extra wear on the inside of the front tires from the more aggressive alignment.
Old Apr 30, 2018 | 03:51 PM
evilchargerfan's Avatar
sweet, i happen to have a set laying around! (looks like wrx camber bolts are the same exact pn)
Old Jun 23, 2018 | 09:24 AM
CodemanGK5's Avatar
Installed these on mine recently after lowering with Koni Orange/Eibach Pro Kit, and what a difference -2 degrees makes in the corners!
Old Jun 25, 2018 | 12:28 AM
did you install yours on the lower, or the top hole?
Old Jun 25, 2018 | 10:47 AM
CodemanGK5's Avatar
Installed according to SPC's instructions, top hole. Loosen the bottom bolt a touch to pivot the knuckle to the desired setting and tighten them both down.
Old Jun 25, 2018 | 11:56 AM
did you use the tab that came in the packaging? or just the bolt itself and nut?
Old Jun 25, 2018 | 11:59 AM
CodemanGK5's Avatar
I used it all, the tab doesn't come off, it's attached to the toothed washer that helps keep the camber setting by gripping the strut with it's little teeth.
I'll try and get a couple pics for you as soon as I can.
Old Jun 26, 2018 | 06:30 PM
the top hole (for koni orange anyway) was perfectly round, and did not leave any room for the tab:
I ended up removing the tab, and installed just the bolt up top. Next go around, I'm gonna try the lower hole since its elongated and does have room to fit both the camber bolt + tab
Old Oct 18, 2018 | 02:05 PM
update:
moved the bolt to the lower elongated hole. was not only able to fit the washer in there, but also gained more camber adjustability. go figure
Old Dec 8, 2018 | 12:05 PM
Shutterspeed's Avatar
update:
older thread but maybe it'll help someone. when you install the camber bolts they go in the top hole. the tab on the washer lines up with the backside of the lobe on the bolt. so if lobe is at 12 o'clock the tab is at 6 o'clock.
Old Dec 8, 2018 | 12:08 PM
can you show us some pictures, of how this is done?
Old Dec 26, 2018 | 07:10 PM
noticed you were installing them on Koni Oranges, this might be why they didn't go correctly in the top hole. Stock struts allow you to use the top one.
