Has anyone here NEVER replaced their coil packs?
I know based on a lot of the talk here coil packs need to be replaced around every 80 miles or so but this is not outlined in the 08 Honda Fit manual. Recently I had experienced some misfires -- had to replace spark plugs -- then a little misfire came back, no codes this time but did valve adjustment. Runs good but not perfect as before so I switched to mid grade gas and guess what runs much better and now I will use premium next time.
So I like to throw this -- safe to assume that most who bought the 07/08 Fit (and ended up replacing coil packs) they used regular octane gas (87) -- however can using premium gas help not degrade the coil packs -- i.e. is there any co-relation between quality of gas and coil packs? For me (car already at around 147,000 km) I havent replaced coil packs but it looks like changing octane level of gas is helping (no misfires have come back). Can there be any sense to this or am I wishful thinking?
Replaced the original plugs with Denso IK22's at 113K and noted the condition of the coil packs - they looked great. I'll wait until one coil pack goes, and then replace all four myself with the Hitachi OEM coil packs from rockauto at around $54US apiece.
I don't have any problems with misfires. I would think misfires would generate codes and would not necessarily be related to coil pack issues. I'm sure others here will weigh in.
I'm running regular 87 octane here in the states, which is up to 10% ethanol. When I take cross country trips, I sometimes have access to non-ethanol gas which is nice, but that's the only break I give it from the normal stuff.
Have you found a difference since switching to 94?
I bought my Fit at 52K and I doubt the dealer changed them out then. I've got about 92K on it now and yet have to replace them. No codes so far. I'll probably replace them when I hit 100K.
Regular 87 octane, 10% Ethanol, which is the only kind available in our metro area.
PS: I adjusted the valves once @ 62K miles, and will prob check them again next summer. And, I'll install new Iridium plugs next year, too.
Thanks, so far so good with premium! Looks like premium for life -- as long as Fit for life :-)
