FS: FS: OMNI RSX CLutch Master Cylinder NEW
Old Feb 4, 2015 | 12:10 PM
IN2TURBOS's Avatar
For Sale: Brand new RSX Omni clutch master with stainless steel braided line which will mount to the Fit to remove the Clutch Delay Valve. I bought it but never got around to installing it and now need the cash.
$125 Shipped OBO
See link below for details of the mod;
https://www.fitfreak.net/forums/2nd-...ster-part.html
Old Mar 6, 2015 | 09:03 PM
IN2TURBOS's Avatar
Price is now lowered to $75 shipped!
Thanks
Old Mar 7, 2015 | 09:39 PM
cnordt24's Avatar
Will it fit the GD? Got any pics?
Old Mar 8, 2015 | 12:32 AM
IN2TURBOS's Avatar
I would think it will fit the GD but I do not know 100%. I can throw some calipers on there and give you measurements if that would help. The pictures are below.
Old Mar 18, 2015 | 03:34 AM
PaeGe8's Avatar
seems pretty interesting. i did a little research but what does this actually do? any problems i should be warned about in the future for just daily driving? thanks
Old Mar 18, 2015 | 07:31 AM
IN2TURBOS's Avatar
The main things is that it shortens the clutch pedal travel while still completely disengaging the pressure plate and removes the clutch delay valve (CDV). The CDV removal was the main reason I wanted to install it. I also drive a 350z (no CDV) and noticed the annoying delay in clutch activation which would cause me to grind gears when trying to shift fast because I was not use to having to wait for the clutch master cylinder.
No problems with it with daily driving unless you are slamming the clutch when releasing the pedal all the time. This could cause some shock to the drivetrain which was the reason Honda added the CDV, but in normal driving this is not an issue.
gd3vbp
84
Feb 11, 2020 01:55 PM
Bounce
Jul 15, 2017 07:28 PM
mnapuran
Feb 25, 2016 05:58 PM
Mister Coffee
May 12, 2015 12:24 PM
Previc93
Sep 8, 2009 11:14 AM
