07 GD3 noise
Old Feb 25, 2015 | 10:17 AM
UnicycleWheelie's Avatar
07 GD3 noise
There is a pretty loud squeaking coming from the driver-side on the engine bay.
It happens when you're almost stopped, then once stopped completely, it goes away.(its not the brakes)
and sometimes it does it when you going 10-20 on a very bumpy road/dirt road.
does this when the engine is cold or hot, and when the temp outside it cold or hot.
To me it sounds almost like a belt squeak but a little faster and non consistent.
I will try to get it on video and upload later today.
Old Feb 25, 2015 | 03:20 PM
derykisonder's Avatar
I would think that the sound that you're hearing is your alternator belt being worn out but you said it was coming from the driver side right?
Old Feb 25, 2015 | 10:24 PM
Yes it's from the driver side...
Old Feb 26, 2015 | 12:30 AM
Camothetrillest's Avatar
I am having the exact same problem with mine, it's a 07 lx, 150,000km. I hear the same squeeking sound your describing, more when I have it idling. It sounds like everything is running smooth and once in a while I hear a squeek. I will have a mechanic look at it tommorow. I will post my findings.
Old Feb 26, 2015 | 06:18 AM
DWils's Avatar
Could it be the front driver side spring?
Old Feb 26, 2015 | 08:07 PM
at 1:09 you can hear it...sorry for the low sound, my iPhone is in a lifeproof case.
Old Feb 26, 2015 | 10:20 PM
doctordoom's Avatar
Supervillain
What's the engine light indicating? Does the car shake with the sound?
It doesn't sound like a belt from your video. Almost sounds like your car is about to stall, but it's hard to say from the video.
Old Feb 26, 2015 | 10:35 PM
It has a missfire, I have installed new plugs, new coilpacks. both from rock auto and to the spec/model number that honda uses.
might be a bad fuel injector? or valves outta spec...also my battery died pretty quickly, so I had to get another one...and my lights sorta pulsate while I'm driving, and everything is the sound and stereo area is bone stock.
I know my fit has 226,XXX miles
Old Feb 26, 2015 | 10:45 PM
doctordoom's Avatar
Supervillain
The noise might be the valves, but I can't say for sure. When's the last time you adjusted them? If it's misfiring, I'd adjust the valves first anyway since that's a problem.
Old Feb 26, 2015 | 10:48 PM
doctordoom's Avatar
Supervillain
Do you have any aftermarket exhaust components? If not, it also sounds like you have an exhaust leak.
Old Feb 26, 2015 | 10:52 PM
I haven't...and I have owned the car since 220,XXX
Old Feb 26, 2015 | 10:53 PM
I have a spoon n1 w/ magnaflow CAT and a CAI
Old Feb 26, 2015 | 10:55 PM
doctordoom's Avatar
Supervillain
If you can, find out if/when the previous owner adjusted the valves. My advice is to start with the valves and then go from there.
Old Feb 26, 2015 | 10:59 PM
Okay, how much does it cost to get all the valves adjusted? like 250 USD or can it be done in a garage ?
Old Feb 26, 2015 | 11:03 PM
doctordoom's Avatar
Supervillain
I've seen some say it costs a little over $100 to have a shop do it, maybe like $115?
Yes, you can do it yourself at home. That's the route some of us take, myself included.
Old Feb 26, 2015 | 11:25 PM
Thank you for being very informational. I will try to get the valves done ASAP
RandomKoko
Jun 29, 2017 09:10 AM
mnapuran
Jun 11, 2016 06:00 PM
blazej
Feb 24, 2016 07:37 PM
3cg
Mar 24, 2015 06:35 AM
tigerseye1108
Feb 8, 2010 08:14 PM
