Question on key/ignition for Fit
Old Sep 25, 2006 | 02:20 PM
FondaFit's Avatar
This is the first time I've had a remote key. It heats up quite a bit after being in the ignition. Is this typical of this type of key, or should I be concerned about the ignition switch overheating?
Old Sep 25, 2006 | 03:24 PM
Fray Adjacent's Avatar
Senior Member
This has been asked before.
I believe it's probably due to the coded key security feature. It's probably some sort of RFID. If the key is left in the field, it's made to 'hum' by RF induction. This will generate heat.
I wouldn't worry about it, it's not likely going to explode. Remember, the Fit has been sold in other countries for several years. If keys were exploding, Honda would have fixed it by now.
Old Sep 25, 2006 | 04:52 PM
FondaFit's Avatar
Thanks -- as long as other people's keys are also doing the same thing, I won't worry. If it's only happening to my Fit's key, then I'll worry!
Old Sep 25, 2006 | 09:24 PM
Awong124's Avatar
Mine doesn't do that (yes, mine is a sport with the keyless entry set into it). But even if that is "normal", as Fray Adjacent said above that it generates heat due to the RF field, I would imagine that it would drain your key battery really quickly. Anything that generates heat will use a lot of electricity.
Old Sep 25, 2006 | 11:02 PM
sy11580's Avatar
does anyone make another Key? Where can get it??
Old Sep 25, 2006 | 11:18 PM
Senior Member
In this case, it would not be the key generating the field, it would be something in the ignition or steering column. It senses the key close to the ignition, and allows the engine to be started. (whereas, someone jacks the ignition, it doesn't detect the key, it doesn't start)
greywolf1940
Aug 9, 2016 02:15 PM
Echeng1965
Apr 27, 2016 03:03 AM
cwapface
Apr 17, 2013 08:52 AM
Eta-Carinae
Jun 16, 2009 11:09 AM
jelliotlevy
Feb 11, 2009 08:12 AM
