Alternator's belt worn indicator.
Hello guys,
1) Is it accurate?
2) How long do these belts lasts?
Mine at 70.000 Km is impeccabile with, no pieces missing and a perfect profile of the rubber lines.
1) Is it accurate?
Today's serpentine belts don't crack, and will continue to look good when they are worn.
The grooves get worn down so the belt's "traction" diminishes.
Gates Rubber used to offer a FREE Belt Wear Gauge, I don't know if they still do...
Gates Belt Wear Gauge For Serpentine Belts | Gates Corporation
Thanks for your replies.
My experience is that they may look ok and then crack all of a sudden.
It is only the serpentine belt, no damage to the valves but the water pump stops working...
I have a BMW motorcycle and the alternator's belt may look ok but around 70.000 Km cracks if not replaced leaving you with a couple of Km of autonomy before the abttery is dead and engine shuts off.
The indicator is situated on the tensioner, see the arrows.
mikejet
Sep 22, 2021 11:04 PM
hazzard
Nov 20, 2013 01:38 AM
