Auxiliary Input Issue
Old Apr 11, 2015 | 04:26 PM
skygunnerblue's Avatar
My AUX jack recently started giving me problems. Basically, when I try to play music through it the music sounds garbled or faint, or it often times sounds like part of the music track is just "missing."
I've tested the speakers, the audio cable, and the audio source - they don't seem to be the problem.
Anyone have any ideas? Has anyone experienced something similar?
Old Apr 11, 2015 | 05:07 PM
Bassguitarist1985's Avatar
Use some contact cleaner and insert the 3.5mm adapter in and out a few times to clean the jack
Old Apr 12, 2015 | 07:37 AM
Gordon Smith's Avatar
I agree. Whenever I've had poor music quality while using the AUX port, it's ALWAYS been the mini-plug connection….sometimes a dirty or funky plug tip, sometimes a funky cable itself.
Old Apr 21, 2015 | 02:22 AM
Good idea, but no luck.
Does anyone know how to the find the part number for the AUX connector? I may just have to replace it.
Old Apr 21, 2015 | 08:49 AM
Not an easy thing to replace. If you have the right tools it is doable. Need to remove the head unit. You need a de-soldering gun, and a replacement 5 pin 3.5mm female jack that has a dual tip/sleeve switch that's normally closed. The next issue is finding the EXACT pin out and pin pitch. Unfortunately Honda does not sell this separately. Likely if you found the right jack but a slightly different pinout you would need to adapt it.
Wpaxton1
Mar 21, 2018 06:01 AM
mariosprob
Apr 22, 2015 11:31 PM
MinesLocal
Nov 3, 2013 02:27 PM
BurntZ
May 17, 2013 09:23 AM
jimjen
Jun 21, 2010 08:07 PM
