Aux Jack Music Question
Old Mar 18, 2018 | 06:31 PM
Wpaxton1's Avatar
I have been attempting to use my LG G4 cell phone to play music via the aux jack on my 2012 Fit. And I am failing miserably. The audio is way low even with the phone volume and stereo volume maxed out. Anyone else have this problem? I am trying to use Amazon Music and Pandora as opposed to my own music that I have on a drive.
Thanks for any help/advice you can offer.
Bill
Old Mar 20, 2018 | 12:41 PM
Andrei_ierdnA's Avatar
You should first narrow your search into what could be the problem.
I'd start with your aux cable - could be the easiest and cheapest fix. Try a different aux cable if you have a spare, or otherwise try the same aux cable with a different sound system.
Another suggestion is to grab a flashlight and look inside the aux jack hole to ensure it's not stuffed with some nasties.
Old Mar 20, 2018 | 12:50 PM
Wpaxton1's Avatar
Checked those
Thanks for responding. Tried several new cables no change. AUX jack has never been used, brand new, unclogged. Issue is the phone for sure.
Old Mar 20, 2018 | 01:10 PM
marmaladedad's Avatar
Have you tried a different device to play music through the Aux jack?
Old Mar 20, 2018 | 02:51 PM
Too bad it isn't as simple as a broken aux cable.
But can come the aux jack "has never been used, brand new" on a 2012 Fit in 2018.
Has this car been hiding under a rock for the last 6 years?
Old Mar 21, 2018 | 06:01 AM
spike55_bmw's Avatar
Have you tried the USB connection in the glove box? Obviously, it takes a different cable than the dashboard jack but worth a try to sort out your issue.
I have an old iPod connected to the USB ('11 Sport AT) and the OEM radio plays, sorts, sees everything (a bit clunky finding "Artists") and the sound can be very loud if you want it to be.
skygunnerblue
Apr 21, 2015 08:49 AM
ydna
Nov 1, 2011 08:19 PM
Keep Fit
May 21, 2006 03:17 PM
李克勤
May 3, 2006 08:59 PM
shipwrek
Mar 31, 2006 12:17 PM
