Brake pedal activates lights without a key
Old Apr 14, 2015 | 08:35 PM
Solscud007's Avatar
So I didnt drive my 07 Fit during the winter. The battery died. I charged it back up and finally reinstalled it and fired up the Fit. My passenger rear bottom brake light wont turn on even with a new LED bulb.
I drove it and noticed a weird clicking noise when I pressed the brake pedal. When I hit the brake pedal my center console lights, hazard button light, and front parking lights come on when I hit the brakes.
When I park the car and take the key out I can press the brake pedal and all those lights come on. With the door open, still with the key NOT in the ignition, the lights come on and the car dings like as if I left the key in the ignition.
Has this happened to someone else? How do I fix it?
Old Apr 15, 2015 | 02:26 AM
DrewE's Avatar
I haven't encountered this specific problem before.
It sounds to me like you have some sort of a cross connection or short circuit between the brake lights and the tail lights/turn signals. Since the one brake light isn't working, it stands to reason that probably the wiring problem is associated with that location.
My first troubleshooting step would be to remove the bulb that isn't working and seeing if the brake lights work normally (except, of course, for the one that isn't there). If so, perhaps the bulb is broken, inserted wrongly, or the socket connections are bad. If the lights still don't work properly, I'd start tracing and checking the wiring from that light cluster back until I found where something was amiss—looking for things like chafing of the wires, rodent damage, etc.
Hope that helps. (By the way, the brake lights generally operate any time the brake pedal is pressed, key or no key, on most if not all cars.)
Old Apr 15, 2015 | 03:54 AM
Carbuff2's Avatar
Originally Posted by drewe
my first troubleshooting step would be to remove the bulb that isn't working and seeing if the brake lights work normally (except, of course, for the one that isn't there). If so, perhaps the bulb is broken, inserted wrongly, or the socket connections are bad.
^^^ this
Old Apr 15, 2015 | 06:19 PM
geopat's Avatar
Its probably a problem with the LED bulb. I installed some in my tail lights and had a similar problem.
Leaky Fit
15
Apr 26, 2022 06:03 PM
kered424
Jan 30, 2014 04:14 AM
yooobake
Nov 28, 2012 10:41 AM
kered424
Oct 31, 2012 05:14 AM
uRabbit
Nov 4, 2009 01:01 PM
