SRS light keeps on visible
Old May 10, 2015 | 01:45 AM
wackyflik's Avatar
My SRS light indicator keeps on visible. I have sent to workshop and remove the error, but after a few days the light visible again. Is that shows my clock spring need to be replaced?
Old May 10, 2015 | 02:46 AM
n9cv's Avatar
It could be that or several other things. You need to have someone with a code reader, read the SRS code(s) to further define your problem. Does your horn work? Sometimes when the clock spring fails, the horn will also fail to work.
Note: The reader that you use must be able to read SRS codes. Most cheap ones do not read SRS or ABS codes.
BradGuy
Oct 9, 2019 05:16 PM
cnb8869
Jul 27, 2015 12:44 AM
Kyaw Kyaw Cho
Aug 21, 2014 07:11 PM
Bocus Iqbal
Sep 14, 2012 12:40 AM
Thor28
May 16, 2007 01:54 PM
