07 Fit issues
Old May 18, 2015 | 08:00 AM
Frank Necrosis's Avatar
07 Fit issues
2007 Fit, auto trans.
Went to start the car, starts fine, but...
Wont shift out of park (brake lights work), none of the gauges work, and power steering is dead. Everything else seems to be working.
I was able to get it into gear and limp it home.
Any thoughts?
Old May 18, 2015 | 05:10 PM
And now it is dead. Engine went into limp mode for a while then shut off. Put the key in the ignition, turn it forward and the entire dash erupts into a symphony of clattering electronics and relays.
Now waiting for the tow truck.
Old May 19, 2015 | 02:19 PM
Spoke with the dealer. The root cause was the #3 fuse blew.
Any common reasons for the #3 fuse to go? I am really hoping it was a fluke and not a symptom of something else.
Old May 21, 2015 | 02:34 AM
DWils's Avatar
What does that fuse control?
Old May 21, 2015 | 08:00 AM
The #3 fuse is for the instrument cluster.
The dealer said that since the cluster was dead, the car would not allow itself to shift out of park as a safety feature. I asked about the power steering not working and he said that was probably a safety feature as well.
For some reason, the car was not charging. I know from past experience with older American cars, the instrument cluster needs to be in place and functioning for the charging system to work. There is usually an exciter wire tied in to the dash and alternator. If the exciter wire is not connected or not passing current, the charging system won't function. I *assume* the same thing holds true for the Fit.
fit_driver_mtl
May 5, 2021 06:20 PM
tck
Aug 15, 2017 08:43 PM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
goalie35
Dec 26, 2012 12:26 AM
