must have shorted something or blown a fuse, but can't find the problem... help?!
Old Oct 4, 2006 | 01:19 AM
Packy's Avatar
Frequent FitFreak Poster
Question must have shorted something or blown a fuse, but can't find the problem... help?!
Hey all,
I screwed up, I'll admit it!
Okay, so I was installing my new map light in the Fit, was nearly done... and right near the end I think I shorted out the hot that goes to the dome light by grounding it.
Right away the dome light went out. After investigating I found the dome light, rear hatch light, radio (no light or display at all), keyless entry and alarm don't work.
I pulled every single stinking fuse after checking the ones that made sense (radio, etc), and none were visibly blown. IS there a fuse for the keyless entry? Or for the dome light? I checked the fuses under the hood, too.
Please let me know any ideas or suggestions you have?!! THANK YOU!
Darin
Old Oct 4, 2006 | 11:49 AM
Packy's Avatar
Sweet, thanks. Running out to the car to check right now. I didn't try checking the huge fuses last night.
Old Oct 4, 2006 | 12:02 PM
Packy's Avatar
Okay weird... so checking the fuses under the hood in the daylight this morning, I found that the "backup" fuse was blown... as in, backup lights I'm guessing, but they worked yesterday! Anyway, I borrowed a 15a fuse from the hazard lights, and POOF, the radio, keyless, interior lighting, etc all works. Go figure! I'll poke around to make sure nothing else is busted.
Old Oct 4, 2006 | 12:46 PM
Packy's Avatar
Cool, that seems to have fixed everything! The map light is now installed and working. Thanks claymore
Old Oct 4, 2006 | 12:48 PM
kps's Avatar
kps
Honda Fit Forums Moderator
"Backup" as in "backup power" for things that still need it when the car is off and the key is out.
Old Oct 4, 2006 | 01:44 PM
Packy's Avatar
^ Thanks. That explains most of the items that stopped working.
I wish the manual had a better breakdown of what each fuse was linked to, but I suppose that's what the service manual is for.
Old Dec 21, 2006 | 06:32 PM
jl0r's Avatar
Excellent!
This describes my problem EXACTLY!
I havn't even checked it yet, but I'm sure this is the fix!
Thanks so much!
Old Dec 23, 2006 | 07:22 PM
Packy's Avatar
Thanks so much!
I'm glad my mistake could help someone else out
Old May 28, 2008 | 10:18 AM
Fit_61's Avatar
Backup Fuse
I blew this 10 amp fuse also. My radio, remote door locks, etc. had stopped working. I think my LED hatch light might have shorted out? Many thanks for the notes on this issue. Saved a Honda service call.
Now I am A happy Fit driver again !
Old May 16, 2009 | 09:34 PM
Koi's Avatar
Koi
Nevermind, was looking at the wrong fuse box.
FELIXY69
Oct 7, 2022 12:48 PM
samson2112
Oct 22, 2010 07:59 PM
setter11
Jun 12, 2010 02:38 PM
espo79
Jun 30, 2008 03:52 PM
Ritzbury
Oct 17, 2007 01:26 PM
