How to remove the front lip
Old Oct 5, 2006 | 02:06 AM
POPiPOP's Avatar
How was wondering how to get the front lip off cause I want to replace it.
Thx
Old Oct 5, 2006 | 12:44 PM
wantboost's Avatar
hmmm..... lol
Old Oct 5, 2006 | 12:56 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
probably some clips on the bottom of it... I have yet to remove mine (no reason)
Old Oct 5, 2006 | 06:27 PM
POPiPOP's Avatar
I know there are 2 screw on each end of the lip. There is no problem getting them out. But it is also hold at two other places, but there's no screw. That's where it bugs me. I don't want a break the lip, but i want to get it off.
Old Oct 8, 2006 | 05:07 AM
bryan720's Avatar
humm il be taking off my lip later on today and il see if i can find the other screws.
Old Oct 23, 2006 | 02:03 PM
wyy183's Avatar
I took mine off to run a dirt/gravel rally this past weekend.
1. Remove the two screws from the ends by the front tires.
2. Remove all the fasteners that hold the under panel in place to the front bumper (several of them, plus two screws.)
3. With the front under panel removed, there are three 10mm bolts that, from the inside, go through the lower bumper into the spoiler. Remove these. I used a ratcheting wrench with made things easier.
4. There are two more fasteners under the front of the spoiler (I don't remember if they need to be removed or not, but I did.)
5. There are two 10mm bolts that have to be removed from the inside of the front lower bumper. I used a 10mm socket with a 3" extension and a stubby-handle ratchet.
6. Once you have everything disconnected, just remove the lip.
7. Re-install the fasteners with the front under panel to hold it back in place. Don't forget the two screws that you removed.
This will leave two small holes in the bottom of the front bumper, which, after looking at it for a day, looks kinda sporty itself - LOL!!
Old Oct 24, 2006 | 01:21 AM
JDMchris.com's Avatar
I run THIS
its super easy if you remove the whole bumper to remove the lip. but like stated above thats what you need to do.
Old Oct 24, 2006 | 02:24 AM
bryan720's Avatar
i took the 2screws off on both sides then drilled out the rivits, i think there were 8 of them. then when i put it back on i just used some screws that i had laying around.
Old Oct 24, 2006 | 02:26 AM
I run THIS
you dont need to drill out the rivets
RandomKoko
Oct 1, 2015 09:02 AM
xonexlifex
Mar 25, 2010 06:33 PM
dmagic17
Aug 22, 2009 04:14 PM
NostalgicFit
Sep 12, 2008 04:34 AM
tin
Mar 24, 2008 10:58 PM
