License Plate Screws
Old Jul 20, 2015 | 07:03 PM
Ameise's Avatar
Hey all,
I just got a new Fit EX (yay) for my Fiancee, and I'm wondering if anyone knows what screws are required for the front/rear license plates? I don't believe we have any, and my fiancee currently has the car so I can't check. I need to put plates on tonight.
Old Jul 20, 2015 | 09:55 PM
DrewE's Avatar
If you can't find the screws, get some from your dealer. If the car doesn't have a plate of any sort on it at present, the mounting hardware may be in a baggie or something somewhere. (I'd also check to make sure all the other pre-delivery stuff has been done, like any body plugs installed that should be and so forth. The dealer should do all that stuff before turning the car over to you; it's part of their job.)
Old Jul 21, 2015 | 03:52 AM
Ameise's Avatar
You were correct, they were there!
For the sake of the thread, when I get a chance, I will post the actual measurements of the screws just in case someone ends up here.
Old Aug 3, 2015 | 08:53 AM
makyong's Avatar
Plate screws are actually issued by our Land Transportation Office.. Failure to use them will give you a ticket/fine of $100.00...the worst place on earth to own and register a car ( philippines)!
Old Aug 3, 2015 | 10:47 AM
bigbacon's Avatar
go back to the dealer and ask them for some?
Old Aug 9, 2015 | 03:48 PM
PearlFit's Avatar
My Fit came with only two bolts holding the back plate to the car. I got tired of the rattle of the plate against the hatch when I closed it, so I added two more bolts. I got them at Home Depot. #10 x 5/8" pan head screws seemed to Fit right.
Old Aug 9, 2015 | 03:59 PM
Peterjens's Avatar
Putting these on my HD list. Thanks.
Old Aug 9, 2015 | 09:14 PM
Splat's Avatar
Be careful with the plate screws. The plastic piece they screw into is super soft - I managed to add a new hole when I attached my metal plate.
rnpollard
Sep 5, 2015 09:44 AM
neteng101
Jan 9, 2010 02:50 PM
Dechy
Mar 9, 2009 12:59 PM
scorpmatt
Washington Community
Jun 7, 2008 11:59 AM
jrstinkfish
May 26, 2007 11:18 PM
