Fuse Box Location
Old Jul 22, 2015 | 06:15 PM
POS-Fit's Avatar
Fuse Box Location
Hi all, I'm having A/C problems and I'm looking for the under hood fuse box. I've only found the under the driver's side dashboard fuse box location. Under the hood, I've only found the fuses on the positive side of the battery and 3 other fuses under the battery. Can someone give me a better idea as to it's exact location? Yes I've used the search button and I've tried searching online but no luck. Thanks.
Old Jul 23, 2015 | 03:49 AM
Black3sr's Avatar
So what are you looking for? There are only two boxes. #10 fuse is for the A/C switch and #29 for the light on the switch.
Old Jul 23, 2015 | 12:07 PM
POS-Fit's Avatar
I was looking for a fuse box that had more than 3 fuses in it under the hood. The smaller box only had 3 fuses or maybe relays and no labels which is under the battery. The positive terminal of the battery had other fuses but isn't what I was looking for. Basically, I'm looking for a fuse box that looks like the one by the drivers side lower dashboard location but the one under the hood if there is even one.
Old Jul 23, 2015 | 12:59 PM
Black3sr's Avatar
So what are you looking for? Another fuse box? If so why? I thought your problem was the A/C.
Old Jul 23, 2015 | 04:17 PM
DWils's Avatar
The Owner's Manual will tell you exactly where both fuse boxes are. It will even give you a diagram of said fuse boxes.
Dedroberts
Jul 22, 2018 12:52 AM
musky123
Jul 6, 2018 10:31 PM
kyo2529
Oct 2, 2007 01:37 AM
FitLIKEaGlove
Feb 17, 2007 11:52 AM
sLiVeRwOrM
May 13, 2006 11:02 AM
