Weird intermittent starting issue, definitely electrical...
Old Jul 23, 2015 | 10:24 PM
budro's Avatar
So it'll start over and over again with no issue at all and then sometimes (this has happened only a handful of times) it'll act like it has a dead battery. The lights on the dash will go dim along with the headlights and it will not start. Not even the "tchk" sound that a dead battery/bad connection will give you when you try to turn the key to ignition. I'll try and push start it and it'll have no affect on the engine. Then after about 5 minutes, or so, I'll put the key in and everything will light up and it will start as if nothing was ever wrong.
The connections on the battery are clean... hell, I put a new battery and new terminals on trying to resolve the issue.
Is there a common problem that is known with a certain cable grounding out after a while or a fuse that would cause this problem.
This is the 2009 with a manual transmission.
Thank you!
Old Jul 25, 2015 | 11:38 AM
Codger01's Avatar
Recently fixed that issue with the wife's Miata. It was the starter motor. We got that replaced and no more starting problems.
kremkaos48
Dec 24, 2018 05:56 PM
IEighty1
Jun 2, 2018 05:51 AM
roland1221
May 31, 2016 10:21 AM
Mister Coffee
Mar 28, 2015 12:22 PM
FLEALAMI
May 19, 2010 12:54 PM
