Paint
Old Sep 6, 2015 | 10:34 AM
hogwylde's Avatar
Paint
In my attempts to keep my paint perfect, I managed to screw up my hood. It apparently can't be wet sanded as easily as a Harley tank and I think I may have to have my hood repainted.
Can you guys give me a rough ball park idea as to what it would cost to have just the hood painted? All the body shops are closed on the weekend.
Old Sep 6, 2015 | 11:29 AM
xxryu139xx's Avatar
show a picture lets see how bad it is. how low of a grit did u go ?
Old Sep 6, 2015 | 12:50 PM
hogwylde's Avatar
It's actually not bad in the sunlight but a complete wreck with the lights of the garage. Will take pics in a few minutes.
Old Sep 6, 2015 | 01:20 PM
hogwylde's Avatar
Here's a few different angles.
And the thing is, I know what what I am doing. Here are my results from wet sanding my Harley after a mishap. And I removed most of the dent!
Old Sep 6, 2015 | 08:18 PM
xxryu139xx's Avatar
well, looks like the clear coat is off. so nothing to wet sand.... ur harley probably has more layers of clear coat than honda paint. those spots look like my accord's paint. all most of the clear coat is peeling and coming off.
not sure, but if the paint underneath is intact, maybe u can pay a shop just to clear coat it. i hear if u try to get them to do it when they are clear coating someone else's stuff u can get it real cheap provided u do all the prep yourself.
Old Sep 6, 2015 | 10:33 PM
MTLian's Avatar
How about try ont to buy that extensive clear coat in a can? Not the cheap kind You get from Walmart but the kind that has a little plunger in the bottom you dépressif to "activate" the clear coat. I think a can is Woerth 50$. With a can of that and some buffing you night be able to fix it?
Old Sep 6, 2015 | 10:48 PM
xxryu139xx's Avatar
its 30 bucks for the can. i have one sitting in a box right now. problem is the clear coat may not match the rest. Maybe with this idea you can rough up the the whole hood with 1000 grit. Spray 4-5 layers. sand down. u get the idea. Might cost u more than one can though.
Old Sep 9, 2015 | 03:40 AM
mtheo31's Avatar
You can respray the hood with clearcoat but the prep has to be done correctly.
Old Sep 12, 2015 | 03:27 PM
hogwylde's Avatar
I think I'm just going to have the hood repainted. So far I've had two different estimates and they were both around $300.
krazyangel917
Dec 7, 2011 03:08 AM
msoulier
Oct 4, 2010 10:51 AM
binaryh4x
Jan 10, 2009 11:41 PM
octophobic
Feb 20, 2008 09:31 AM
clk1022
Aug 28, 2006 08:15 PM
