Fit`s Emblems led lighting
Old Oct 12, 2006 | 03:12 PM
URAN's Avatar
Front emblem:
I used 6 leds, but I`m sure it could be 8 or 10.
suiting
half of emblem filled with clue
seems like led`s bodies dissolved in clue
ver.1
ver.2 (I like it more)
almost done
under pressure for 24 hours
next day (it works!!!)
on my Fit
Old Oct 12, 2006 | 03:16 PM
URAN's Avatar
And the rear one
stuff. I failed to find piece of red plastic elsewhere
8 extrawhite leds
Old Oct 12, 2006 | 03:25 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
hey, cool writeup nice little mod.. is it on all the time or do you have a way to turn it off?!
Old Oct 12, 2006 | 03:42 PM
koolkevin1107's Avatar
yeah thats pretty cool. You DEFINITELY need 2 take much better pictures and w/o the rain and PLZ use a tripod
Old Oct 12, 2006 | 03:49 PM
aziatiklover's Avatar
Master FitFreaker
not ba I like hte LED white for hte license better
Old Oct 12, 2006 | 10:03 PM
8251reefer's Avatar
Looks really nice. Do they come on with your head lights ?
Old Oct 13, 2006 | 01:54 AM
URAN's Avatar
Front emblem connected for power supply from headlight and rear one - from rear number lighting (also led)
I`m too lazy I guess
Old Oct 13, 2006 | 02:53 AM
GoFits's Avatar
What brand LEDs did you use for the license plate lights? ...ordid you fab up something? I wanna buy some LED bulbs but the last pair I had failed after a not very long time.
LOOKS GOOD BTW!!
Old Oct 13, 2006 | 03:10 AM
URAN's Avatar
LOOKS GOOD BTW!!
I use DIY led license plate lights, made of 5 mm extra white leds.
You can find two report here - http://www.hondafit.ru/forum/index.php/topic,261.0.html
Old Oct 13, 2006 | 10:03 AM
kps's Avatar
kps
Honda Fit Forums Moderator
They overheated. There's a lot of garbage on the market. Don't buy anything that's intended to be bright (i.e. just about anything other than dim interior accent lighting) if it uses 5mm (or other) round LEDs or the tiny surface-mount ones; if you use those in a DIY project keep the current to around 5mA unless they're turn signals. Otherwise stick to pirhana-style, Luxeons, or something similar with heat sinks.
Old Oct 13, 2006 | 12:21 PM
uiskibum's Avatar
what can you tell us about this setup?
Old Oct 15, 2006 | 12:56 AM
URAN's Avatar
I can`t say anything about it, I found this example of installation somewhere on Japanese web and tried to make my own one.
I`m not clearly understand previous post about overheating, but I can tell that leds stay cold after hours of lighting. If you would like to made DIY led light you should use resistor about 220-250 mA per one led.
Old Nov 5, 2006 | 09:26 AM
twicetheage's Avatar
I bet that does look sweet on the street at night. Anybody due a simple light up of the little blue "jewel" in the dot on the "i" of Fit? I'm thinking 1 or 2 LEDs. Power is right there inside the hatch lid. I'm more concerned about the type of LED and the circuitry. I've the posts here about getting good LEDs, and not burning them up. Are we talking simple V=IR here? Just need to stick a resistor in series to limit the I?
Old Nov 5, 2006 | 12:58 PM
kps's Avatar
kps
In this case you're not depending on the LED to keep someone from crashing into you, and you're not mounting it beside hot lamps, so you don't have to worry much; just use a cheap 5mm LED and keep the current well below the rated maximum. R = 1.2K or 1.5K should be about right for a typical 'anonymous' blue LED.
I don't think the blue dot is translucent, so you'll probably have to replace it. If I were attempting it I'd start by trying clear epoxy with a drop of blue ink added.
Old Sep 15, 2007 | 05:38 PM
OneStopCustoms's Avatar
i can't see the pics...
Old Sep 15, 2007 | 08:23 PM
doctordoom's Avatar
Supervillain
probably because these posts are from about a year ago, so they pics might not be where the links lead anymore. the last post before yours was about 10 months ago.
SilverEX15
23
Jan 25, 2019 09:33 PM
mr2spyderman
Mar 20, 2018 07:48 AM
Jus Garcia
Jan 11, 2014 01:45 PM
kustomimports
Sep 23, 2013 07:55 PM
theindiearmy
18
Jun 30, 2011 10:38 AM
