Warn Out Your Tires, Yet?
Old Jan 7, 2016 | 09:23 AM
SilverEX15's Avatar
Have any of you warn out the tires on your 12015 Fit, yet? I'm wondering how long they'll last. Typically, tires on a new car aren't the best, so it will be interesting to see. I have only 13k miles on my car, with 7/32" left on the tires.
After rotating them, the TPMS light came on, as it says it will in the Owner's Manual. Now I'll have to read the manual - again - and try to turn it off.
Old Jan 7, 2016 | 09:31 AM
Uncle Gary's Avatar
My tires wore faster than that due to an "out of spec" rear axle which had to be replaced under warranty. As it is, I project I'll get maybe 25,000 miles out of my OEM tires (I won't run them below 3/32). Three of mine were at 6/32 and one at 4-5/32 at 13,000 miles.
Based on my experience with OEM tires on two Fits, I have to believe that the people who claim to get 50-60K on the OEM tires are either:
A- Lying. Or:
B- Running them until the cord starts to show, or:
C- Driving on pillows instead of pavement.
Old Jan 7, 2016 | 11:11 AM
kbonus's Avatar
I'm at 21K and expect to get 25-28K before replacement. About typical for OEM tires in my experience. Mostly highway driving but regular windy mountain roads at speeds in the upper 40s to low 60s so I suspect those trips took off a bit of extra tread....
Old Jan 7, 2016 | 12:07 PM
exl500's Avatar
There's a thread "OEM Tread Life" that got moved somewhere. You can find it on search.
Old Jan 7, 2016 | 01:29 PM
2Rismo2's Avatar
I've warned my tires not to get worn down too quickly
Old Jan 8, 2016 | 08:57 AM
Uncle Gary's Avatar
I told my tires that too, and they told me, "get some snow tires, cheapskate!"
Old Jan 8, 2016 | 10:06 AM
bach's Avatar
I agree about the short life of OEM tires. Only good OEMs I ever had were the Michelin set on my GTI.
Old Jan 8, 2016 | 01:47 PM
stembridge's Avatar
I only put about 500 miles on my OEM Bridgestones before installing aftermarket wheels and tires. I ran snow tires last winter, so that saved some miles, and my Continental summer tires probably have around 28K on them so far. The rears show some misalignment wear (not bad), and I may look into shimming at some point. If it ever starts snowing in earnest here in the Middle West this Winter, I'll put my snows back on, and will expect to be needing new summer tires by the end of this summer (2016).
I, too, have never had much luck with factory-fit tires. In fact, I'm about to order a set for our '12 Routan as they're worn far enough to really not be safe in snow and ice.
es
Old Jan 8, 2016 | 08:47 PM
GeorgeL's Avatar
The purpose of OEM tires is to keep the rims off the ground until the car is sold. Other than that manufacturers spec the cheapest they can get away with and the tire manufacturers have no motivation to sell them a long-wearing product. Firestone, as we know, tends to cut it finer than most manufacturers.
I've been lucky to get 30K out of a set of OEM tires on any car, and that is with relatively conservative suburban driving.
One might be able to get 40K out of a set of OEM tires, but you can only drive moderate speeds on the highway and avoid anything that resembles a turn.
Old Jan 9, 2016 | 08:23 AM
Fit_as_a_butchers_dog's Avatar
Warn? Really?
Old Jan 9, 2016 | 12:56 PM
hogwylde's Avatar
I'm still running the OEM's on my '09 Sport with 41,000 miles.
Old Jan 9, 2016 | 08:15 PM
rodney's Avatar
all depends on use. Harry houdini got over 60k out of his, whereas i got 20k.
Old Jan 18, 2016 | 04:11 PM
CommanderSlug's Avatar
I just replaced my oem's at 26,000 miles with a winter set. They are going straight to the garbage/recycle bin.
Old Jan 18, 2016 | 06:09 PM
hongzhibin1987's Avatar
Actually I did. I had ~12K miles on the original tires. And I did 1 rotation middle of the year. The front condition was pretty bad (mine was firestron 755? can't remember the details). Was expecting longer but my wife ran on nails and one is completely messed up.
Anyway got the bridgestone ones from costco and so far am pretty satisfied with those.
Old Jan 19, 2016 | 09:15 AM
bigbacon's Avatar
we will be replacing ours in the spring with something a tiny bit wider and stickier. 12k miles on our and they seem ok still..the tires themselves just suck
Old Jan 21, 2016 | 01:23 PM
kenji815's Avatar
they should last 20,000 to 25,000 miles
i'm at 110k and the it's about half way done.
Old Feb 17, 2016 | 05:01 PM
Colonel Panik's Avatar
New Kumos today. 37,982 on OEM "stones"
Should have changed them at 32,000.
Fink007
Jul 29, 2015 06:17 PM
Jack92029
Apr 19, 2014 03:45 AM
minitruckersfit
Jul 22, 2010 10:43 PM
Sean D
Mar 31, 2009 06:18 PM
kodo
Jun 24, 2008 03:09 PM
