HID intall issues!
Old Oct 16, 2006 | 10:51 PM
jits14's Avatar
HID intall issues!
I have a hidexpert kit, installing and lights aren't working. Has anyone installed these and can maybe tell me what I am doing wrong.
I will contact the company tomorrow but I thought it would be awesome to fix it tonight. It seems to be something in the adapter plug and the wires, my guess. I have everything else setup appropriatly to my knowledge. Any help would be appreciated.
Old Oct 18, 2006 | 05:02 PM
Tomh's Avatar
Senior Member
Don't forget to use some higher amp fuse's too.
Old Oct 18, 2006 | 05:23 PM
jits14's Avatar
Yeah it didn't come with replacement fuses and I spoke with the seller and he said nothing about em. I got them running and they look great though.
Did you end up installing higher fuses outside the kit? I actually bought these from what I believe was your recommendation on a thread, so you have this mchullah kit installed in your fit? Did you get fuses with the kit? I am new to the owning/installing of a car with HIDs, I have a lot of questions.
Old Oct 19, 2006 | 04:44 PM
Tomh's Avatar
Senior Member
the shop i got my kit from recommended for me to get a higher amp fuse, before installing them, i think stock was 15amp's, and i got a 30amp replacement fuse, sinc emy kit didn't come with them either.
Old Oct 19, 2006 | 05:00 PM
koolkevin1107's Avatar
i didn't get any higher amp fuse for my hid's i'm still running the same. I don't see why you would get a higher amp fuse when the HID'S take LESS amperage then a regular bulb....
Old Oct 19, 2006 | 05:03 PM
gettinafit's Avatar
That plus the car's stock wiring isn't meant for a higher amp fuse, you might melt wires if there is a sort to ground somewhrere!
Old Oct 20, 2006 | 08:16 PM
michaelfit84's Avatar
im guessing HID's void some sort of warranty...unless you dont have any problems due to the lights
Old Oct 23, 2006 | 04:45 PM
Tomh's Avatar
Senior Member
i have had my HID's in the whip since may, and no issue, i had teh same exact kit in my civic hatch for almost a year, and no issue there either.
Old Oct 24, 2006 | 12:20 AM
same here. As long as u keep ur stock fuses and don't upgrade nothing and just change out the bulbs you can't get your warranty voided. I have taken in my fit to the dealership that i got it from n i told em i have hid's and they are cool w/ it b/c im not changing anything but the bulbs (and adding a balast)
Old Oct 24, 2006 | 12:42 AM
siccmonkey's Avatar
the "plug and play" kits dont seem to work, the stock wiring doesnt wont provide enough juice to fire up the ballasts.....i been screwing with the same issue all day, through the provided harness...nada....straight to the battery nice H.I.D... im just going to go buy some relays and build my own damn harness...
Old Oct 24, 2006 | 04:41 PM
Tomh's Avatar
Senior Member
My kit came with a relay between the ballast and the bulb, i guess i sorta got lucky on that.
Old Oct 29, 2006 | 07:45 PM
jsmonet's Avatar
for these you always, always, always run direct power via relay from the battery.
Old Dec 13, 2006 | 02:28 AM
potatoo's Avatar
my cheap kit reversed the freakin' + and - wire at the first H4 plug to the ballast, if it ****ed up the kit i would have been choked. great that i have my computer power supply handy and gave it a nice 12V to try it out with and used my multimeter and found the wiring was reversed from the factory, goddamn!
Old Dec 31, 2007 | 11:21 PM
danger69's Avatar
Hey guys can you tell me on my USDM fit what wire is lo beam and which is ground. There is red/blue, red/white and red/yellow. Please help.
Old Jul 8, 2008 | 08:02 PM
1stgenciviclvr's Avatar
My HID kit, "Helligkeit" has not included relays how and where do you install these. Haven't tried installing them yet, just want to try and avoid frustration, thx
Old Jul 8, 2008 | 08:09 PM
kelsodeez's Avatar
UNBANABLE
try flipping around the fins on the male plugin that goes to the headlights. i have installed three different hid kits in my car and ive had that problem every time. just try it until it works.
Old Jul 8, 2008 | 08:10 PM
kelsodeez's Avatar
UNBANABLE
also, ive never heard of anyone getting bigger fuses for an hid kit. i dont see how that would help as the hids take less power to function.
Old Jul 8, 2008 | 08:53 PM
SD_MR_FIT's Avatar
yessir. just play around with the prongs. it will work eventually
Old Jul 9, 2008 | 01:31 AM
Fit4Trav's Avatar
That's what I did.
Old Jul 10, 2008 | 12:46 AM
accordguyintake's Avatar
The reason why you'd want higher amp fuses is that initial power is more than stock bulbs, this probably wont be an issue if you have a relay to use the battery power, but if it's hooked up straight to the headlight harness, then most likely your fuses will blow
