Air conditioning issues
Old Apr 12, 2016 | 09:27 PM
lief101's Avatar
Question Air conditioning issues
Hello all.
I'm trying to isolate an issue with my AC. Recently, my system has not been cooling properly. The compressor kicks on no problem when I toggle the AC button in the cabin. However, cold air only comes out periodically. I recharged the system to manufacturer specs and added AC dye to re-check for leaks. Nothing was immediately apparent, but I'll be lkeeping an eye on it over the next couple of days.
One other thing that I notice when I toggle the AC button is the only time the AC actually works is when the compressor kicking on is followed by a sort of "gas escaping hissing" noise. It's hard to explain but what I hear pretty much immediately follows the compressor kicking in. Then nice cold air. No hissing noise, no AC.
Could that be the drier on condenser or something? Could I have a bad relay or a bad thermostat? Any suggestions are appreciated as to how I can further diagnose the issue. I can provide manifold pressure levels if needed.
Very much a diy guy here, so go easy on me if my terminology is off. :-)
Old Apr 22, 2017 | 05:34 PM
Yagi13's Avatar
Can you tell if the hissing noise is coming from behind the glove box?
My Fit has an aftermarket expansion valve and it seems to make a hissing noise after the compressor kicks off...
tdoom15
Sep 28, 2025 05:15 PM
BigSpark
May 7, 2021 03:42 PM
phybere
May 29, 2018 11:46 PM
taxonomy
Jun 17, 2017 10:08 PM
geepondy
May 23, 2017 01:54 PM
