07 Help with first DIY front break job
Old Jun 2, 2016 | 12:39 PM
tgr23's Avatar
My front break rotors have gone all rusty and need to be replaced. I've done front breaks and rotors on many other cars but not Honda's. Anything I should be worried about or know? Also what is the best online source for these parts?
Any video's or tutorials online?
Thanks in advance!
Travis
Old Jun 2, 2016 | 07:02 PM
roland tuck's Avatar
Dear tgr23. Try to clean and recover before replacing with a new one. Are they worn and/or damaged? It would be too expensive to take on a lathing workshop and perform a clean hit to the surface ?
Old Jun 3, 2016 | 03:03 PM
Carbuff2's Avatar
Honda secures their rotors to the hub with small Phillips (actually JIS) screws. You may need an impact driver to remove them. If you are in a salty climate, you may need to drill them out.
You should clean and repack the slider pins on the calipers with synthetic brake grease. Don't mix up the top & bottom pins, they are different.
Your new pads should 'fall out' of the top & bottom holders. If they are tight, they could bind and wear rapidly. Un-clip the stainless guides, file or sand the rusty bits underneath until the pads are loose, then coat with brake grease to prevent future corrosion.
PS Don't forget to de-rust, lubricate, and adjust the rear drum brakes, too. SEARCH for instructions on that. The shoes are probably still in good shape.
Old Jun 3, 2016 | 05:37 PM
tgr23's Avatar
Great info!!
Thank you very much.
I ordered the rotors and 8 screws, just in case.
Travis
Old Aug 11, 2016 | 08:45 AM
jeng's Avatar
I don't think new rotors are that expensive. And yes, an impact driver is necessary. Good luck!
Old Aug 11, 2016 | 05:27 PM
dwtaylorpdx's Avatar
Rock auto sells name brand rotors and pre powder coated calipers for the GD... Cheap.
Hasafraker
Dec 28, 2014 10:20 PM
Thurst63
Mar 14, 2014 11:48 PM
pmartensen
Jan 11, 2013 06:08 PM
kancerr
Jan 16, 2011 08:10 AM
mjletts
Aug 23, 2009 09:07 AM
