Stick shift
Old Jul 20, 2016 | 11:40 PM
fritz269's Avatar
Stick shift
Prob a dumb question but the gear shift numbers are upside down or slightly sideways. What is the best way to fix so they face the correct direction? Also can I replace the skirt on the shift? It's got a small rip.
Old Jul 21, 2016 | 07:29 PM
Alco RS-1's Avatar
I'm not sure about the Fit, but most all manual shift knobs are simply screwed on. A twist ought to orient it correctly. My Fit is an Auto, so I can't address the boot around the shift, but this too should be easy, often with removal of the center console.
Old Jul 29, 2016 | 08:40 PM
yah, if u can't tighten any further try some thread lock at the position u like and let it sit overnight to dry.
Old Aug 5, 2016 | 05:37 PM
Uncle Gary's Avatar
The knob is just threaded on with an interference fit. Just turn it until it aligns properly. I had to adjust mine a slight bit.
Old Aug 11, 2016 | 08:14 AM
jeng's Avatar
Masking tape and a Sharpie marker. You will have personalized your Fit like no one else on the planet!
413FitMurtz
Jan 30, 2016 11:35 AM
Downshift
30
Jan 17, 2015 12:04 PM
Wafulz
Nov 5, 2012 07:06 PM
cojaro
Sep 26, 2007 12:37 AM
Squab
Aug 9, 2007 07:11 PM
