Samsung Galaxy S5 + Mirror link
Old Jul 24, 2016 | 07:09 PM
bigbacon's Avatar
anyone else have this problem with an android phone in the 2015 Fit?
So say I want to charge my phone, I plug in a USB cable, plug the other end into either of the USB Ports and ..... it doesn't charge.
Mirrorlink tries to do something and can't. the screen on my phone goes blank and doesn't come back until I unplug the USB cable.
This didn't happen when we first got the car but it started some months ago.
I don't seem to have any mirrorlink apps installed on my phone either.
I just want to charge the darn phone.
Old Jul 24, 2016 | 08:29 PM
TorontoBoy's Avatar
Try a 12v to USB charger instead. The USB ports only have about 1a of power.
Old Jul 24, 2016 | 08:58 PM
Tinyplaces's Avatar
I have the same phone and I think I had the same problem before when I first got the car but I'm not too sure b.c its been a while since I tried my phone in the usb port. I've been using a usb car charger. I just tried this again to see if there was anything different with ver 6.0.1 and its the same behavior as you describe. I even tried disabling mirrorlink via the application manager and that lets me use the phone but it wasn't getting a good charge from what this app was telling me. That app is not suppose to be 100% accurate but it gives a you general idea of how many amps the phone is getting. I was getting 450mA
Old Jul 24, 2016 | 08:59 PM
bigbacon's Avatar
Not the problem though.
Old Jul 24, 2016 | 11:27 PM
salamlaith's Avatar
the USB port is NOT for charging, its for playing MP3 files from a USB flash ram.
Old Jul 25, 2016 | 11:04 AM
bigbacon's Avatar
pretty sure that is 100% NOT true.
I can charge my phone no problem with it (Lumia) my wife was able to charge her phone with it before. It charges MP3 players even if you not using them for music. It charges portal battery packs.
I mean it charges everything I throw at it like a normal USB port does just with my wife's S5, whenever she plugs it in, the car tries to take it over and then the phone just doesn't operate anymore until you unplug it.
Old Jul 25, 2016 | 11:05 AM
bigbacon's Avatar
how did you disable mirror link? Guess I need to check exactly what version she has.
Old Jul 25, 2016 | 11:26 AM
salamlaith's Avatar
I have LX 2016, not charging my phone Lumia 640, if it does it will be veeeeeeery slow
Old Jul 26, 2016 | 12:17 AM
tbFit's Avatar
Not all charge cords are capable of providing maximum current. I've bought quite a few and the big thick ones are the best for full current. On my Samsung Galaxy, there is an app you can use to monitor charge current so you can try out different cords. I'm pretty sure I get more than 1 amp with the cord I use.
Old Jul 26, 2016 | 08:55 PM
bigbacon's Avatar
again you are all not understanding.
cables and everything charged the phone no problem months ago..now it doesn't. cable doesn't matter.
Old Jul 26, 2016 | 09:56 PM
tbFit's Avatar
Sounds like the port has gone bad and time for warranty work.
Old Jul 26, 2016 | 09:58 PM
bach's Avatar
What you're saying is that at one point it just charged and now it's trying to connect. Something changed on the phone, I'd start with MirrorLink. There are a few MirrorLink threads on this forum that might give you some clues.
Old Jul 27, 2016 | 12:57 AM
Tinyplaces's Avatar
Sorry, I forgot to mention that my phone is rooted and I used LINK2SD
to disable it.
I don't know if its possible to disable it on non-rooted phones since its a system app but this is how to see it in the app manager.
Settings>Application Manager
set it to "All apps" then press the 3 dots on the top right and press "Show system apps"
It will be titled "Samsung MirrorLink 1.1".
The disable button is probably grayed out, it is for me even though I'm rooted that's why I used the app I mentioned above.
Old Jul 30, 2016 | 01:21 PM
Jack Hammer's Avatar
I've used the USB ports to charge my S5, Ithe gets buggy, sometimes it will charge, other times it won't. Other times it randomly tries to connect your mirrorlink . I just use a 12v dual USB charger and am much happier now
Old Jul 31, 2016 | 04:25 PM
tbFit's Avatar
I just confirmed that I get a full 1.9 amps with my thick charge cord and only .8 amps with my thin cord. I used the galaxy charge app that works with my S4 and shows the current charge current. The 1.9 amps also matches my high capacity original wall charger.
So bottom line, the USB port under the dash in the '15 EX is capable of at least 1.9 amps with the right cord.
Buck Fitty
May 17, 2018 11:06 PM
dwjngs@gmail.com
Jun 14, 2017 02:13 PM
Shipoffools
Mar 12, 2017 09:59 AM
sissiromy
Jul 22, 2012 10:06 PM
SkEEzY_GT
Mar 20, 2011 10:09 PM
