Shift from N to D while moving
Old Aug 3, 2016 | 11:41 PM
steven691's Avatar
Hi, recently while driving, my gf accidentally pushed the gear level from D to N.
I noticed when I'm revving but car is not accelerating.
After that, I took my gas off, tried to brake slightly and shift back to D.
Will this cause any damage to the transmission or engine?
Old Aug 4, 2016 | 08:17 AM
Fuelish's Avatar
I ain't no expert, but am gonna guess no...have owned a variety of cars over the last 40 years, several of them automatics, and this has happened on all of 'em at one time or another....oops....have never had a transmission problem ...ever...on any car. I wouldn't make a habit of it, necessarily, but, am sure they're built with the possibility of this happening in mind, or somwhere near the back of their minds. As long as you're off the gas, it should slip back into Drive smoothly...You should be fine. BUT, of course, have never owned a CVT trans car, but assume it would be equally fine....my Fit is a 6 spd manual
Old Aug 4, 2016 | 08:21 AM
stembridge's Avatar
I've done it before (on purpose). No issues. You probably don't want to go around doing it all the time, though.
es
Old Aug 4, 2016 | 10:32 AM
salamlaith's Avatar
happened with my corolla many many times, no problem at all
Old Aug 4, 2016 | 03:23 PM
andre181's Avatar
You're fine. I do it all the time on accident thinking I'm going from S to D, but I'm going D to N.
Just let it go down to idle and put it back into D from there. No harm done.
Old Aug 5, 2016 | 12:27 AM
DrewE's Avatar
I agree, no problem at all. It's designed to be able to do this. If you should ever have the engine die while you're rolling and it's not practical or safe or easy to come to a stop, you can shift into neutral to restart and get power again.
Old Aug 5, 2016 | 08:06 AM
yep as others have noted unless you're reving high and neutral drop into gear while in motion, should be no problem. im pretty sure the oems anticipated our occasional brain farts.
Old Aug 5, 2016 | 08:07 AM
not to mention i did the same on my DGS gearbox
i still kinda suck at driving AT cars... lol
Old Aug 5, 2016 | 08:21 AM
Reddogs's Avatar
I do it all the time, just let the foot off the gas, and put back in gear...
Old Aug 5, 2016 | 08:35 AM
stembridge's Avatar
What's more embarrassing is switching from a manual to an automatic and accidentally slamming the brake pedal thinking it's the clutch!
es
Old Aug 5, 2016 | 09:35 AM
tsand19151's Avatar
es
HA!!!! I had that very issue!! After decades of driving manual VW's, the first few days in my FIT were embarrassing. I can truly state that the brakes in the FIT are excellent! Luckily no one was behind me.....
Old Aug 5, 2016 | 10:34 AM
exl500's Avatar
That was my Dad when he got his first auto in 1965.
Old Aug 5, 2016 | 08:31 PM
DrewE's Avatar
I suspect most everyone who has switched back and forth has probably done that at some point or another. It's right up there with groping around empty space for the shifter when it's mounted on the steering column, or turning on the windshield wipers when you meant to shift out of park....
Old Aug 5, 2016 | 08:56 PM
tbFit's Avatar
es
Yep, did that once in a rental on a business trip 30 years ago when all my cars where manuals. About put myself through the front windshield.
Old Aug 6, 2016 | 03:21 AM
Fuelish's Avatar
Heh....kind of an opposite end of the spectrum story, but, yet, a true story. Way back when (my older brother had graduated from college and bought a Fiat 850 Spider, must've been early '70's), it was "street sweeping day" and all cars had to be off of the streets....my bro was sleeping, and my dad, having driven big American automatics for decades, decided to pull his Fiat into the driveway -
this car had an impossibly narrow stretch between the pedals, and when my dad pushed on what he thought was the brake, he only depressed the clutch and ran through the garage door!!!! LOL.....my brother was not happy, although damage was extremely minimal to the car, bent the steel bumper back from the top a bit, rest of the car unscathed...was a cheap light garage door, luckily
Old May 19, 2023 | 10:00 PM
Mueller747's Avatar
D to N without trigger?
Hello group,
I was just out driving with my hand on the shifter of my 2019 Fit and all of a sudden it was in N. Did I break the lock from going to D to N or is it like that? In other words it made me pose the question of the normal operation is such that D to N does NOT require pressing the trigger?
Old May 20, 2023 | 02:43 AM
tsand19151's Avatar
Originally Posted by Mueller747
Hello group,
There is no lock. This is normal operation.
Old May 20, 2023 | 02:46 AM
Mueller747's Avatar
Thanks for confirming it since I. Worded my subject the other way around I’ll ask again I am in D and it clicked into N without the trigger being pulled - again one more time normal?
Old May 20, 2023 | 03:10 AM
tsand19151's Avatar
Normal. The lockout is only on the reverse gear.
GeneralLee86
Aug 5, 2014 11:55 AM
TheRealBenzo
Apr 8, 2010 09:34 AM
MT5_Fit
Aug 10, 2008 02:06 PM
Fray Adjacent
Feb 16, 2008 12:11 AM
jagreen2
78
Feb 15, 2008 11:05 PM
