Help with motor mount
Old Oct 22, 2016 | 12:28 AM
Coaster1's Avatar
Hi all.My 09 fit has way too much idle vibration
Mechanic says it's likely this passenger side mount.
A can you tell me if it looks sunken or too low?
... I insert pic but it won't show up. Help.
Old Oct 22, 2016 | 12:42 PM
Carbuff2's Avatar
Usually, the LF trans mount fails first.
Try posting your pic on a hosting site such as Photobucket.
Old Oct 23, 2016 | 07:04 PM
Coaster1's Avatar
Here.
Old Oct 23, 2016 | 07:47 PM
Carbuff2's Avatar
Can't tell from that angle, sorry.
The rubber center of the trans mount has 'legs' that crack and allow the drivetrain to 'fall'. After a while, the metal center and the metal edge contact, and knock or clunk.
Looks like this:
More Information for DEA / MARMON RIDE CONTROL A65012
Old Nov 5, 2016 | 08:34 PM
Coaster1's Avatar
Looks like this:
Where can the mechanic look to examine this part?
Would I be able to take pic?
Thanks.
Old Nov 5, 2016 | 11:11 PM
doctor J's Avatar
Use jack to lift the engine about 1/8" under pan to remove weight from the mount
If vibration lessens the mount is bad.
This is hydraulic type mount with the motor bracket is attached to the stud which is attached to membrane with thick fluid (like a gear oil) above and below it
When membrane completely tears the mount sinks down. Not sure about "partial failure" like small cracks in membrane.
What typically happens, the rubber parts are getting stiff (especially during winter) and fails to isolate vibration from the body
Old Nov 5, 2016 | 11:17 PM
Coaster1's Avatar
Thanks.
I can feel the vibes in the steering wheel and in my drivers door.
mechanin changed the spark plugs recently... told me 2 were loose. i think shake caused this.
Old Nov 6, 2016 | 01:15 PM
Carbuff2's Avatar
Actually, loose plugs are a common issue. You are lucky they didn't blow out of the cylinder head!
Regards inspecting the part... You could look up from underneath, might have to use a mirror on a stick (aka, Inspection Mirror) to see.
doctor j, I didn't know Fits used hydraulic dampers. Our '99 Acura TL did.
Old Nov 15, 2016 | 09:19 AM
Charly's Avatar
How many miles on your car?
Old Nov 15, 2016 | 11:02 AM
arrow_runner's Avatar
If you have access to the tools, this is an easy part to replace yourself. Just make sure you use a block of wood between the jack and the oil pan. I replaced all 3 of mine and that was the easiest to get to.
ChuckDustin
Apr 12, 2019 12:47 PM
88self
Jun 13, 2017 11:18 AM
allmotormark
Oct 10, 2014 01:16 PM
mxl180
Sep 1, 2014 11:37 PM
lcq4blackstar
Jul 13, 2011 06:04 PM
