Question on rims
Old Dec 12, 2016 | 06:03 AM
Snapplekid50's Avatar
Question on rims
Hi all
I have a ge6 2008 fit, planning to get the following rims, and will lower the car eventually.
The rims are Enkei JS+M rims with the following specs, 4x100 15x6.5J ET+38, question is will they fit and will the tyres rub the fender when its lowered?
Current tyres are 195/60/15
Old Dec 12, 2016 | 11:45 PM
spootnik's Avatar
Originally Posted by Snapplekid50
Hi all
Yes it will rub, stick to offset +45 if you do not want rubbing. At most you can go offset +42 but you will then need to run some 195/45 tyres.
Even at offset +45 it will rub with the inner fender tabs with your 195/60 tyres under hard driving if loaded.
I have used 17x7 +40 205/45/17 lowered on Buddy club and eibach. Rubbed all the time pretty much unless camber adjusted.
I am using 15x5 +45 195/55/15 lowered on eibach and my tyres currently sit right under those inner fender tabs. (6-8cms)
EDIT: Mine is a GE8 yr2011
p nut
Sep 11, 2014 04:15 PM
jazz_do_it
Apr 28, 2010 09:21 PM
Fat Ping Cat
Feb 19, 2009 12:23 AM
MarkB
Apr 16, 2008 04:43 PM
nikeflex
Feb 26, 2008 07:00 PM
