VolkRays TE37 rims - offset question
Old Apr 24, 2010 | 10:05 AM
jazz_do_it's Avatar
Exclamation VolkRays TE37 rims - offset question
Im planning to buy a VolkRays 16" rims for my 2007 Jazz GD3.
What offset would fit best?
I want something that won't stick out or rub with the fenders when i drop the car down into the lowest possible drop. .
All replies would be much appreciated. .
Thanks in advance . .
Old Apr 24, 2010 | 11:21 AM
JDMchris.com's Avatar
I run THIS
+42is fine.
Old Apr 24, 2010 | 11:43 AM
MNfit's Avatar
+42 would be ideal, but there is a chance you will rub a bit if you are very low. I rub when I hit big bumps.
Old Apr 24, 2010 | 11:55 AM
Jimmy101's Avatar
I believe these come in a 50 offset, the factory offset is 55, so that
is very close, you should be able to special order these.
Old Apr 24, 2010 | 10:33 PM
jazz_do_it's Avatar
thanks for the replies and suggestions ..
i looked at a shop but they only have +40 offset . .
i think these will probably be going out the fenders a bit and will probably have some rubbing issues. .
I think a +50 offet would be great but finding even a +45 is hard . .
Old Apr 28, 2010 | 07:53 PM
THEproFIT's Avatar
don't listen to anybody that didn't ask what size tires u plan on running
it's quite amusing (very disturbingly) when u actually think about it
think common sense
175 vs 225
35 series vs 60 series
hmmmm
Old Apr 28, 2010 | 09:21 PM
Jodele's Avatar
Dimensions of the Honda 16" Accessory Wheel
The Honda 16" Accessory Wheel is 16 X 6.5 with a 55-mm offset
If you go up to 7" wide, this is what happens...
Choose wisely
Happy__Fit
Jun 16, 2010 01:19 AM
Chikubi
23
Mar 30, 2009 10:13 AM
sbualuba
Jan 31, 2009 02:04 PM
rvall004
May 20, 2008 04:08 AM
Frenchi169
Mar 31, 2008 10:49 PM
