Fitment question from newbie
Old Jan 28, 2017 | 01:26 PM
Jeremysayshello's Avatar
Hey everyone! First post here.
So Im pretty confused on tire size, and i did as much research on here and other sites and i just cant seem to find the answer. So on here i seen lots of people running 18x7 or 18x7.5 with different off sets (which i do not understand at all) So i'm loving these xxr matte/flat black XXR Wheel Rim 530 18X7.5 5x100/5x114.3 ET38 73.1CB. So i know i will need at least a 5mm spacer to make sure not to rub. However I just wanted to ask you guys to make sure before i buy these that it will work with the dimensions.
i drive a 2012 base model with factory suspension (factory hight)
Thanks for the Help
( XXR Wheel Rim 530 18X7.5 5x100/5x114.3 ET38 73.1CB Flat Black - Part Number: 53087102 - Sparktec Motorsports - 530 )
Old Jan 29, 2017 | 05:45 AM
spike55_bmw's Avatar
I can't help but notice that these wheels are 5-lug. You need 4-lug. Look great though.
Old Jan 30, 2017 | 01:17 PM
Very true our cars are 4 lug, but this one is a multi fitment and has 8 so fits many cars.
Old Jan 30, 2017 | 01:43 PM
shinjari's Avatar
Welcome to FF!
Based on the description you posted, it clearly states 5x100/5x114.3
The picture on the link however shows a 4-lug 16" wheel.
Also if you goto XXR's website XXR 530
You will see that they do NOT offer a 18" in a 4lug pattern. Largest you can get is a 17" wheel.
Offset basically determines how much the wheel will tuck (higher offset) or stick out (closer to 0 or negative offests). Believe our wheels are +42 from the factory.
I run a +35 and they fit decent. Probably better if I were on a 15x7.
danielabel
Apr 21, 2018 06:22 AM
kj9024kr
Jan 29, 2016 05:45 PM
CHRISP1
Apr 18, 2013 01:21 PM
pandayun
Mar 14, 2012 12:26 AM
