Accessory socket (center console) not working
Old May 7, 2017 | 09:50 PM
oiric2006@gmail.com's Avatar
I bought a front and rear camera which I plugged in the front socket. I have a USB adapter plugged in there before i bought the camera. When I tried to use the accessory socket on the center console, no power was coming from it. I checked my manual on where the fuse is located, checked it with my tester light and it lit up. I plugged my USB adapter on it then plugged my phone to charge but still there was no power coming from it. The manual says not applicable on certain model (when i checked the fuse location). I have a 2015 EX 6 speed I don't want to go to the dealer just for this.
Old May 8, 2017 | 01:12 AM
iggy's Avatar
Should be fuse #36 under the steering wheel fuse block.
Is that the one you checked? Should be a 20 Amp
Should be the top of the far right row.
Old May 8, 2017 | 01:13 AM
iggy's Avatar
Duplicate Msg
Old May 8, 2017 | 10:00 PM
jaevans's Avatar
It may not be related, but of interest to some. I have a USB thumb drive with music plugged into the low dash port and that works fine UNLESS I try to charge my phone in the console USB port. At that time, songs hang and the player jumps to the next tune, only to repeat that cycle until I disconnect the phone. I suspect the player is seeing the phone as a memory device and that conflicts with my thumb drive. My solution is to use a lighter adapter to charge the phone.
Old May 8, 2017 | 10:04 PM
iggy's Avatar
I need to try that out with a USB.
Has anyone tried the HDMI for playing a video?
Old May 9, 2017 | 01:29 AM
It is related, I am using the cigarette socket as a charging port with an adapter because when I try to use the USB port my phone goes to mirror link mode then goes to error display. My phone is an S6.
Buck Fitty
May 17, 2018 11:06 PM
mbfavreau
Jul 18, 2015 08:46 AM
SilverEX15
Jul 30, 2014 03:10 PM
ADVphotography
Jul 21, 2014 03:18 PM
Shaar
Feb 16, 2011 04:16 PM
