Looking for Honda TCS codes
Old Nov 23, 2017 | 11:55 AM
The Proper Fit's Avatar
I've looked and looked, but I'm coming up empty.
Does anyone know where I can find TCS codes?
They are from a 2001 Acura CL, and the codes are: 31, 34 and 61.
Thanks.
Old Nov 23, 2017 | 02:17 PM
ezone's Avatar
Code info from an Accord v6 same year:
Code 61 ignition voltage....may or may not be related to the current issue (could be a history code)....chart just says to erase the code then drive it above 10 MPH and see if code resets....
but you probably have to solve the other codes first
31 front right inlet solenoid
34 front left outlet solenoid
spec
inlet solenoids 8-10 ohms
outlet solenoids 3-5 ohms
Two different solenoid codes at the same time makes me wonder if you might have a wiring problem....got rodents?
Old Nov 23, 2017 | 02:25 PM
Thanks so much.
Do you know where I can find all the TCS codes online?
Not sure about rodents. This car was inherited with issues!
Old Nov 23, 2017 | 02:37 PM
ezone's Avatar
No I don't
Try autozone/Alldata or Mitchell on demand
Google honda abs codes or acura abs codes? (TCS is part of the ABS system)
Old Nov 24, 2017 | 09:53 AM
Actually, the ABS light is flashing its own code (13: wheel sensor: open/short to body; ground/short to power LF)
The TCS light is flashing those other three codes.
Old Nov 24, 2017 | 11:14 AM
ezone's Avatar
13= left front (left is drivers side) WSS
FITDragon
Nov 11, 2021 09:08 PM
Smackhead-johnny
Nov 11, 2016 04:15 AM
65olds88
Mar 2, 2016 05:11 PM
Marrk
Sep 14, 2013 01:28 PM
Steve
May 4, 2005 11:16 AM
