2018 Fit bulb and installation
Old Dec 4, 2017 | 12:49 PM
Daniel.Lam's Avatar
Just recently bought a 2018 Fit and wanted to know if anyone knows the bulb sizes for headlights and fog lights. LED is preferred and installation instructions would be appreciated. Thanks
Old Dec 4, 2017 | 08:21 PM
sneefy's Avatar
Not to be unwelcoming as this is your first post, but this is the laziest thread I've seen in months.
Search. You'll find your answers in less than a minute. http://bfy.tw/FOKJ
I apologize if I offend. I just can't stand it when people expect to be spoon fed.
Old Dec 4, 2017 | 10:11 PM
Daniel.Lam's Avatar
No offense taken at all. I understand that I could find an answer online. I wanted to be sure about fitment and have directions before I started pulling my car apart. I am pretty new to this kind of stuff. Thanks for the advice though. I just wanted some help from people who own the newest model just in case anything has changed.
Old Dec 9, 2017 | 09:42 PM
Spyke's Avatar
I mean, if you've never owned a car or a flashlight in your whole life I would find this justified.
Old Dec 21, 2017 | 10:19 AM
Aznsupastar's Avatar
i'm in the same boat as u, looking at the manual, it looks like 2018 still has the same H4 in the low/high beam, and H8 in fogs.
i also looking for HID/LED replacement, and it looks like u will run into DRL issues as 2015-2017 models (DRL in halogen is a low voltage, so it won't be enough to power HID/LED and u will have no DRL which can be an issue). i'm no expert at this but the forum is pretty dead compare so i don't think u will get much responses. good luck fellow 2018 owner...
Old Dec 21, 2017 | 10:37 AM
2Rismo2's Avatar
DRL is in highbeam so if you keep that halogen, you don't have to worry about it. Don't really think it's worth the expense to hid/led highbeam since you're not using it 99.99% of the time anyways.
Old Dec 21, 2017 | 01:16 PM
Daniel.Lam's Avatar
Thank you, friend!
I found some​​​ Cougar LED on Amazon for the hi/lo.
H4 LED work fine as drl. Good luck!
Old Dec 22, 2017 | 09:06 AM
r u saying any H4 LED will not have the flicker issue when in DRL mode?
any H4 LED kit will work in the high/low beam since they are designed that way, but i'm uncertain about DRL mode. let me know how kit goes!
Aussie
Mar 21, 2018 04:18 PM
Aznsupastar
Jan 27, 2018 06:35 PM
zongld
Dec 28, 2017 08:42 PM
person118
Jul 29, 2017 07:42 PM
