Warning: 2016 Honda Fit Catalytic Converter Failure
Old Feb 22, 2018 | 05:19 PM
2015honda's Avatar
fuel bashing thread
10characters
Last edited by 2015honda; Feb 27, 2018 at 09:19 AM. Reason: thread caused too much hostility between members.
Old Feb 22, 2018 | 05:59 PM
hasdrubal's Avatar
The cost of an RV6 downpipe with cat is $429, and the catless version is $100 less. Not sure on labor, put it in myself, but even the catless version doesn't throw any codes. Both versions retain the EGR pipe.
Edit- not suggesting people avoid using their warranty, but if you're out of warranty and don't want to pay the cost of factory parts, there's an option available that even keeps the cat.
Old Feb 22, 2018 | 09:49 PM
Gregg's Avatar
The catalytic converter is part of the vehicle's emission control system.
Under Federal Law, its warranty goes far beyond the standard 36,000 miles or three years. If the cat is bad, the dealership should replace it under warranty.
If they argue with you, just call Honda Corporate, 800-999-1009
Old Feb 22, 2018 | 10:04 PM
Originally Posted by 2015honda
Hey all,
Have a 2016 Honda Fit. Owned since new. Always put in 87 octane.
Had check engine light come on around 25,000 miles. Dealer said it showed Catalytic Converter and said they cleared the code and that I probably put in 85 ethanol fuel and I need to stop doing that. (which I have never mistakenly put in the wrong fuel. E85 is not that common in Oklahoma and Texas. Besides, even if I had a vehicle that would take it, I wouldn't use it due to the poor fuel economy of E85 over regular)
Several thousand miles later, the check engine light came on again. Took it to dealer and asked for a difference service advisor. Technician said Catalytic Converter failure code. They called Honda and Honda told the dealer they have been having to replace Catalytic Converters on the Honda Fits. The Part was replaced under warranty.
So if this happens to you, be aware that Honda knows there is an issue and don't let the dealer push you off if you are getting close to warranty expiring. The cost of a new Catalytic Converter is over $900 installed by dealer.
thanks for the heads up. my GK is also right around 25k..
Old Feb 22, 2018 | 10:15 PM
woof's Avatar
Originally Posted by Gregg
The catalytic converter is part of the vehicle's emission control system. Under Federal Law, its warranty goes far beyond the standard 36,000 miles or three years. If the cat is bad, the dealership should replace it under warranty. If they argue with you, just call Honda Corporate, 800-999-1009
According to my Canadian 2018 warranty manual the catalytic converter (and a few other emissions components) are covered for 8 years or 130,000 KM (80,000 miles). I would imagine the US warranty is comparable.
Old Feb 23, 2018 | 09:14 AM
Uncle Gary's Avatar
Without looking it up, I believe the US emissions warranty is similar.
Old Feb 23, 2018 | 11:23 AM
ashchuckton's Avatar
Hey all,
Thanks for the heads up on this. Cat converters ain't cheap. Very glad Honda warrantied that for you.
Old Feb 23, 2018 | 11:36 AM
justanewbie's Avatar
In Ontario here, came here to say cat died at 59540km, so did one of the spark plug causing misfire.
Dealer replaced everything including fuel injector
Old Feb 23, 2018 | 02:44 PM
GAFIT's Avatar
My bet is that an injector failed which took out a plug and catalytic converter.
Cat's last a long time under good circumstances, but can fail very quickly with a misfire or faulty injector.
I would not be surprised if we hear that the OP ends up with a problem again. Generally speaking, a failed catalytic converter is the symptom of a different problem.
Old Feb 23, 2018 | 03:19 PM
You are most likely right. Raw fuel into a CAT will kill it in short order. Although it is interesting that the dealer said they are seeing dead cats on those Fit's.
Old Feb 23, 2018 | 04:10 PM
GAFIT's Avatar
Probably all Direct Injection related. Compounded if not using Top Tier fuel as recommended in the manual.
Here's how it goes...
Carbon deposits build up on backside of valves which restricts air flow. Car runs rich. Plugs foul and catalytic converter fails. If the fuel is especially bad or the car isn't run hard enough, the carbon fouling can even extend into the combustion chamber and foul the plugs or cause injector failure.
Hence, the dealer seeing more catalytic converter failures. I'm sure it all began with 2015 models due to DI. Cars that aren't run hard, are used for short trips, or get low quality fuel will fail faster than others.
Old Feb 24, 2018 | 08:08 AM
yah, ive not read about cat failures on the GD and GE..
Old Feb 24, 2018 | 08:45 AM
2Rismo2's Avatar
Is this really a systemic problem or a way for the dealership to save face for trying to deny a replacement under warranty? I haven't really heard of cat failures on numerous GK. I've seen more reported issues with the starter.
Old Feb 24, 2018 | 10:43 AM
ezone's Avatar
On these engines that use direct injection, fault codes related to the cat at unusually low mileage have been most commonly caused by fuel injector problems....likely at least one of the injectors is overfueling.
Replace injectors and the cat code usually stays gone, without replacing the cat.
Not all techs understand this, even in dealership shops.
Many just read codes and toss parts without digging deeper.
Old Feb 24, 2018 | 11:32 AM
Unfortunately many times they just throw parts at it to see what sticks. This is OK when it's a warranty repair. It really can hurt if it's on your dime.
Old Feb 24, 2018 | 12:08 PM
GAFIT's Avatar
For warranty repairs, it's even worse because the manufacturer often won't authorize what is actually needed for the repair. They would rather apply a band aid and hope it goes out of warranty before having to fix the actual (more expensive) problem.
The OP's car probably needed at least one injector, possibly a carbon deposit cleaning, and a catalytic converter. Since the cat itself is causing the check engine light, it got just the cat. They will now hope it makes it out of warranty without the light coming back on.
Old Feb 24, 2018 | 01:02 PM
woof's Avatar
I disagree. These cat failures are occurring on low mileage cars where carbon build up will not yet be a problem - if it ever is. Even on high mileage cars there have been virtually no reports of carbon causing any problem on the Fits.
On the other hand there have been many injector problems and if memory serves me right the early GK injectors were redesigned at some point in time and replaced with a new part number(?). It may very well be that these early injectors by themselves are in some cases causing the eventual cat failures. Nothing to do with carbon build up.
Old Feb 24, 2018 | 06:27 PM
ezone's Avatar
The manufacturer really does want the cars fixed, fixed correctly, and fixed in a timely manner.
A low cat efficiency code (P0420) does not always automatically mean the cat has failed.
The fault code is simply the result how the PCM has interpreted sensor inputs during self tests.
One (or more) injector squirting too much fuel is all it takes to cause a cat code on these (and other) DI engines.
The same cat may pass the PCM's self tests again after the overfueling injector problem has been corrected.
Old Feb 24, 2018 | 07:13 PM
GAFIT's Avatar
I agree about the injectors, but there have been carbon build up issues as well. Here's just one example, but we've seen a few on these boards...
https://www.fitfreak.net/forums/3rd-...-too-lean.html
Regardless of if it's injectors and/or carbon build up, I see it as a DI problem. It's the DI type injectors that are failing.
Old Feb 25, 2018 | 01:35 AM
Cichlid_visuals's Avatar
Stop putting 87 octane in an 11.5 to 1 compression ratio engine, especially if it isnt up to par on detergency. If you insist on putting 87, make sure its chevron, shell, 76, or mobil. Fuck everything else, these cars are so economical you cant afford NOT to use quality gas.
Early (1/15) mexican lx 6mt, 91 chevron almost exclusively, 44k HARD miles (lots of redline, lots of rev match/heeltoe downshifts). Not a single part replaced except air filter and headlight bulbs. Idemitsu zeppro 0w20 with moly, and hamp small filters exclusively. I average 36.3 mpg per tank of mixed freeway/mountain roads, i dont drive conservatively.
Maybe im just lucky, or maybe quality gasoline and strict maintenance really make a difference in these apparently highly sensitive engines.
I am noticing a HUGE correlation between people who use crap gas, and injector failure on these cars. These are not your typical injectors, they operate at extremely high pressures (500 psi at the fuel rail) and have multiple tiny ports for high atomization (essential for direct injection). Shit gas will clog these ports, and/or make the injector stick open in a hurry.
