If you have a GE8 Sport, could you confirm?
I'm not sure if I am seeing this incorrectly but when you unlock your car with the remote key fob, your amber lights in the front and rear lights goes on and off correct?
I had my car serviced for my passenger airbags and I believe the flashing lights in the front is no longer coming back on since they performed the job.
Thanks all for the reply. I closed the hood once after I noticed it not lighting up and the right side did it once and hoping it will fix it on the left side, I closed and opened the hood again and now it isn't lighting/blinking anymore.
I also tried swapping the known working bulb (right side) to the left side and still a no-go.
Apparently, our Fit and nearly all cars have a hood sensor but I am trying to see if it was related to the dealership opening and closing the hood to access the battery for the airbag that might have messed with the hood sensor.
I will be coming to the dealership first thing tomorrow and have them "check and advise"
ejd1987
Nov 4, 2015 09:18 PM
pandayun
Dec 21, 2011 04:12 PM
