LED Headlights?
Old Apr 24, 2018 | 06:47 AM
SilverEX15's Avatar
LED Headlights?
Have any of you tried LED headlight bulbs? Apparently, they are very, very hot. They run so hot that they include a 10,000 RPM fan, and you can use them underwater!
https://smile.amazon.com/Headlight-C...eadlight+bulbs
Old Apr 24, 2018 | 08:33 AM
mizike's Avatar
I recently installed the Beamtech LEDs with the fan. The housing of the lights without the fan was too big for the wire locking mechanism. Im satisfied....Im not sure if the fan speed hits 10k rpm but it is very quiet and the low light LEDs are a huge improvement over the factory bulbs. The high beam LEDs are weak as sh*t tho.
Old Apr 24, 2018 | 08:47 AM
SilverEX15's Avatar
How did you deal with the wire locking mechanism? I wonder why they all use that system. I think a quarter turn twist would be a lot simpler.
Old Apr 24, 2018 | 08:51 AM
mizike's Avatar
The locking mechanism (you're right, it is a PITA for oversized bulbs), is thin enough to be bent and twisted. So I basically shaped it so it fits over the fan. The dust cap you'll need to invert to make it fit over the fan.
Old Apr 24, 2018 | 08:56 AM
Action Jackson's Avatar
Using the Philip$ fanle$$ LED'$ bulb$. Couldn't be more happier. Would like to do my own HID retrofit, but for now I'm content.
Old Apr 24, 2018 | 09:00 AM
SilverEX15's Avatar
Was it a simple installation, or was the size of the bulb okay?
I put HID on a couple of other cars, and I wouldn't do it again. Too many parts. Too many things to go wrong, and if one part fails, you don't have a headlight, and the police notice that.
Old Apr 24, 2018 | 11:46 AM
No problems with installation.
Old Apr 24, 2018 | 04:55 PM
Uncle Gary's Avatar
I used fanless LEDs from Superbright LEDs. They run much cooler than the halogen bulbs that I was using before. The heat sink gets warm, but not too hot to touch. I'm delighted (no pun intended) with them. The DRLs even work with them.
It's not that the LEDs run that hot, but that LEDs can't handle the kind of heat that incandescent bulbs can without failure.
Old Apr 24, 2018 | 05:05 PM
SilverEX15's Avatar
I think you'd be de-lighted if the bulbs burned out.
Old Apr 24, 2018 | 09:03 PM
justalilbit's Avatar
I imagine they cause unpleasant glare to other drivers at night. Most LED applications in crystal halogen housings don't work well with LED light in that regard.
Old Apr 24, 2018 | 09:24 PM
at least the headlights will work when engine is hydro locked in a flood! ..lol
Old Apr 24, 2018 | 10:22 PM
Uncle Gary's Avatar
I depends on the LED unit. The ones I use duplicate the location of the filaments of an HB2 lamp and produce a nice sharp cutoff on low beam. I’ve been using them for over three months and haven’t been “flashed” by traffic yet.
Old Apr 25, 2018 | 06:48 AM
SilverEX15's Avatar
I'm getting the elevated air intake kit for mine. : )
seanpatrickk
Aug 10, 2015 07:32 PM
Marrk
Sep 29, 2013 02:19 PM
Mugen_Dom
May 13, 2006 10:18 PM
Todd K.
Aug 1, 2005 11:52 PM
Al Davis
May 15, 2005 07:30 PM
