When does your gas light come on?
Old May 1, 2018 | 04:58 PM
GQ_Style's Avatar
On my 2008 Honda Fit Sport automatic, the gas light comes on with around 1.2 gallons of fuel left. Hills can trigger it earlier. When does it come on for you guys? Wanted to see if there is a spread.
Old May 1, 2018 | 10:32 PM
SHAG's Avatar
The steering wheel blocks the light on my 2017
Old May 2, 2018 | 07:40 AM
Carbuff2's Avatar
1.0 ~1.3 gallons is about right. Yes, hills can make it illuminate earlier.
Don't run it down too far. Remember, the gasoline cools the in-tank pump. Once in a while won't hurt it, but long term you may reduce the life of the fuel pump.
Old May 4, 2018 | 01:07 PM
Andrei_ierdnA's Avatar
I've noticed a similar range of around 5 liters (L) = 1.4 gallons of gas in my case, but I've got the GE (2nd gen) Fit if that makes any difference. And this is only a 'guesstimate' based on the specified volume of the gas tank (40 L) - in real world applications we should also account for the entire length of the gas filler pipe as well, not only the tank - which in the case of our Fits is quite a long pipe that stretches to the front seats and can add anywhere from 1-3 L extra.
Either way, as a general rule of thumb, the triggering of the gas light is never based on any accurate specific volume of gas leftover in the tank. Factors like temperature and hills will trigger the gas light to come on sooner or later than the average.
zensah
Jun 10, 2014 05:41 PM
running
Jul 25, 2012 10:11 PM
mega56
Oct 13, 2008 10:37 PM
pcs0snq
May 26, 2008 08:14 AM
kev01
Jul 30, 2007 07:28 PM
